Old 12-06-2016, 01:48 PM   #1
HTR Switch
Is this HTR switch on the left to turn the water heater on with propane? Have never used the heater with propane only electric. Thanks
2015 Ram Mega 3500 DRW, 2016 Vengeance 377V
boatman22 is offline   Reply With Quote
Old 12-06-2016, 01:52 PM   #2
wmtire's Avatar
boatman22, were you perhaps trying to attach a pic with your post?
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 12-06-2016, 01:56 PM   #3
I guess that would help.....
Old 12-06-2016, 01:59 PM   #4
I guess if I click the correct button it will work......
Old 12-06-2016, 02:06 PM   #5
wmtire's Avatar
Yes, that appears to be the switch to your propane/DSI with the fault/reset bulb to it's right (in between the HTR and PUMP switches).
This detailed link may help explain it better:
Suburban's electric switch and much more
Words are powerful.
Choose them good.
Old 12-06-2016, 02:20 PM   #6
Thanks for the info. I have always turned off the WH at the breaker when I have it stored in the garage and the trailer plugged in to shorepower. Does the water heat faster when using both propane and electric?
Old 12-06-2016, 02:22 PM   #7
Yes! Quicker recovery time.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 12-06-2016, 02:31 PM   #8
wmtire's Avatar
Yes, according to Suburban the recovery times are 6 gallons using the electric element, 10.2 gallons using propane...or 16.2 using both at the same time,
The following is taken from their website link below:
Take advantage of campground or generator power to heat your water.
A 1440 watt Incoloy electric element provides a recovery rate of 6 gallons per hour. For a FAST RECOVERY rate of 16.2 gallons per hour, both gas and electric can be used simultaneously.
Combinations Gas & Electric Water Heater
Words are powerful.
Choose them good.
Old 12-06-2016, 02:32 PM   #9
I just went out and looked at the WH. Looks just like the photo in the doc you linked. Great info.....Learning more everyday......
Old 12-06-2016, 02:40 PM   #10
wmtire's Avatar
Good deal, I went ahead and added the recovery rate information to the Suburban FAQ link.
Words are powerful.
Choose them good.
switch
