Old 02-09-2016, 09:29 PM   #21
Yes! I old the receiver to hide HD channels And the channel name does not show HD in the channel. For example it just says A&E instead of A&EHD
Bond is offline   Reply With Quote
Old 02-09-2016, 09:37 PM   #22
rracer5's Avatar
OK....good there. Try B-band converter this weekend. And straight thru cable, no splitters.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-09-2016, 09:51 PM   #23
Still plan on just running through the window again. At least until I get it working. Maybe we won't freeze.
Old 02-09-2016, 10:15 PM   #24
rracer5's Avatar
Do you have an outside connection labeled "Satellite". If not, it probably won't work thru the "Cable" connector. Satellite cable voltage doesn't like splitters or amplifyers.
2014 Sanibel 3250
Old 02-09-2016, 10:34 PM   #25
No it's just labeled as cable. I'm sure it runs through amplifier. If I can get it working running through the window I will do some rewiring for easier connection next time.
Old 02-10-2016, 12:47 PM   #26
rracer5's Avatar
2014 Sanibel 3250
Old 02-10-2016, 08:25 PM   #27
We are having the same issue.
We got our King Quest in today and went to set it up. We are using a Directv D12-100 SD receiver. We have used this receiver on numerous 18" dishes in the past with no issue. We connected the receiver to the dish using the supplied coax from King Controls. Everything seemed fine except the receiver continually says searching for signal. When we go to view signal strength - it is 95+ on all the ODD transponders but 0 on all the even transponders. Like I said - we are connected directly to the dish - not going through any existing coach wiring. We are going to try a different coax cable to see if that works - any other suggestions?
Thanks!
rfikes is offline   Reply With Quote
Old 02-10-2016, 08:41 PM   #28
Exact thing mine is doing. If you go to channel 300 it will probably work but CMT A&E etc won't work
Old 02-10-2016, 10:24 PM   #29
Play Harder's Avatar
King Quest Directv problem
Receiving only one of the 2 transponders 13V or 18V odd / even is normally due too:
Non power passing splitter in line somewhere
Bad fitting
Bad cable
B band converter
Bad LNB
Play Harder is offline   Reply With Quote
Old 02-11-2016, 04:52 PM   #30
rracer5's Avatar
Thanks!
Bad fitting
Bad cable
B band converter
Bad LNB
This could be the solution to both of above. The King Quest dishes may require a B-band converter.
2014 Sanibel 3250
