Old 06-11-2017, 12:34 PM   #1
Leaky ramp door
So took a trip last weekend and it poured for about 100 miles on our way home, when we stopped to get gas and let the kids use the restroom the inside of the camper was soaked, it was coming in all around the rear door there was water pooled all the way into the bedroom, anyone else have this issue, 2017 26RR grey wolf, I'm not very happy it's been in the shop more than we've camped in it.....Click image for larger version
ID:	140896Click image for larger version
jasonw is offline   Reply With Quote
Old 06-12-2017, 06:27 AM   #2
I had a 27rr 2017 just traded it in had to manny issues slide out leaked and the back door. They had finally fixed back door from leaking like yours is the latches were not putting enough pressure on door for seals to work. They replaced the latches and the seals. They also put a rain gutter over the door as it should be . When your door is closed and you look up at the seals I bet you will see light.
roadrash2012 is offline   Reply With Quote
door, leak
