Old 11-22-2016, 10:29 PM   #1
Loft/Bunk Bed side rail ideas
I have a loft bed with about a 30" opening with ladder access and the over size queen Bunk Beds in the garage that lower down. Anyone have any ideas or DYI ways of making a rail system along the side of the Loft/Bunk Bed to keep kids from rolling out while sleeping?
RowdyCowboy is offline   Reply With Quote
Old 11-22-2016, 10:49 PM   #2
https://www.amazon.com/Kids-Bed-Safe...node=166872011
Any of these from Amazon work?
2016 Vengeance 3062V - SOLD
2013 Ram 3500 4x4 CC DRW 6.7L
2015 Harley CVO Limited
2015 Harley CVO StreetGlide
Funhaus is offline   Reply With Quote
Old 11-22-2016, 10:55 PM   #3
Oaklevel's Avatar
or Wal-Mart
https://www.google.com/#q=walmart+bed+rail+toddler
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-22-2016, 11:09 PM   #4
Fulltime family RVer
We use a $12 rail from IKEA. It worked using its own clamps for pressure for a while but ultimately just drilled through and permanently mounted the thing. It's more difficult making the bed now, but 100 times more secure.
Before that, we used a cheap "under the mattress" rail. It only worked because we added 4" of foam to our factory bunk "mattresses". Otherwise, the existing mattress would have been way too thin to work.
Old 11-22-2016, 11:19 PM   #5
gectisme's Avatar
X2, and ependydad you were right, eventually I had to drill and add screws and nuts too.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 11-22-2016, 11:24 PM   #6
However, with such a short opening- I'd just take a 1x6 and curve over the edges (either ugly by hand with a rasp or prettily with someone with a router). Then do some vertical mount- similar to the "legs" of this IKEA one.
Old 11-23-2016, 01:40 PM   #7
Topspud
loft and bunk protection
we used a cargo net that has some stretch. mount to the base of net to the bunk/bed base. use the hooks over the frame above teh bed. if you do not need, you can store under the mattress.
Topspud is offline   Reply With Quote
Old 11-23-2016, 02:07 PM   #8
When our kids were young, we attached a cargo net to the outer bed rail base and then hooks holding each upper corner. With a corner unhooked, the kids could get out without having to climb over a rail. It was a cheap and effective fix. When the net was not needed, we stuffed it under the mattress-out of sight and out of mind. There are cargo nets made to go vertically across the bed of a pickup and this would be about the right dimensions.
Check Amazon with the phrase "Pickup bed cargo net retainer". This is one example:
https://www.amazon.com/Zento-Deals-P...o+net+retainer
PenJoe is offline   Reply With Quote
Old 11-28-2016, 08:36 AM   #9
Loft gate fix for $30.
Baby Bed side rail cut down to fit (Scratch & Dent $20)
Hinge & Latch ($10)
*hopefuly my son won't fall out again*
ID:	125841   Click image for larger version
Old 11-28-2016, 09:12 AM   #10
Life is great's Avatar
This is what we have for our daughter. Works great to keep her in bed and keeps items in place while travel. I don't remember where got it but should be easy to find and install.
Name:	2016-11-22 20.45.58.jpg
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
Life is great is offline   Reply With Quote
Old 11-28-2016, 09:21 AM   #11
Someone on this forum suggested using pool noodles. We got the large diameter ones and cut them to fit. Place them under the sheet when making the bed. They work very well.
bigmurph is offline   Reply With Quote
bed, bunk, loft
