Old 06-26-2016, 05:57 PM   #11
RiderBloke
RiderBloke's Avatar
Originally Posted by hiinthesky View Post
How do you determine where to place your wheel choke? Do you want the bike half way in front of the axles??? Where would you place the choke if you want to haul two bikes? Would you stagger the bikes or load in single file? I guess you would put the heavier bike up front...??? I will get my new Wolf 26 RR 2nd week in July, so I kinda need to come up with a plan....
I would put the heavier bike at the back. The 26RR is already very tongue heavy and the front bike will add to that somewhat while the rear bike will help take some weight off. Remember that the weight of the rear bike will still be not far from the rear axle because of its overall length.
Also the spread of the tie downs is wider at the rear for sideways stability with the greater weight.
If the lighter bike is skinnier it may also help access to the kitchen.
Sent from my iPhone somewhere on the face of the earth using Tapatalk
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 06-28-2016, 01:29 AM   #12
DodgeNerd85's Avatar
Shockwave F28SAGDX (WA2812G,F285GSLR) w/ slideout, loading motorycles.
Here's my input on using chocks
2015 Stealth 2812G
2012 3500 Mega Cab DRW
ISR Series SuperGlide 16K
GO NAVY
DodgeNerd85 is offline   Reply With Quote
Old 06-30-2016, 11:18 AM   #13
for the Harley bikes this would be the only thing I would use:
https://www.etrailer.com/Trailer-Car.../BWMC2301.html
No straps, no worries.
racenviper is offline   Reply With Quote
Old 06-30-2016, 12:01 PM   #14
AMG
On all my sport bike forums people either use a PitBull Trailer Restraint System or a Baxley wheel chock.
I have a Baxley knockoff I got on Amazon. Works great but isn't $200
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 11-29-2016, 10:51 AM   #15
I took a piece of aluminum angle iron and bolted my chocks to that. I than cut slits in the bottom of the angle iron so that the drings would come through it. So that when the bike is in the chock the d ring and hook of the strap holds the angle and chock down. Once bikes are pulled our I remove the angle and chocks as one unit and I have a nice flat bunk house
Psykokustomz is offline   Reply With Quote
Old 12-31-2016, 09:12 PM   #16
ChipBruce's Avatar
Saw this posted on the Keystone forum page. They look nice and don't bolt permanently. I hope this helps someone.
http://www.boltiton.com/wp-site/
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
Old 12-31-2016, 10:02 PM   #17
2007 WildCat 32QBBS
05CrewDually's Avatar
That's pretty neat and easily frees up the room by releasing the j-hooks from the d-rings in the floor.
I'd still strap the back wheels down for 4 point attachment.
05CrewDually is offline   Reply With Quote
Old 04-06-2017, 06:17 AM   #18
What wheel chocks are you using? We have an Ultra Classic and a Heritage Softail Classic to put in new toy hauler. Don't want to mess with the heated underbelly and drilling. Your set-up might be what we need with no drilling in the floor.
2harleysnus is offline   Reply With Quote
Old 04-06-2017, 08:04 AM   #19
SeaDog's Avatar
This is the stand I use for my ultra classic you might want to take a look at these.
https://wheeldock.com/products/wheel...nt=26294025411
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-06-2017, 08:19 AM   #20
x2 on the Wheel Dock.
guyster is offline   Reply With Quote
motorcycle
