Old 07-16-2015, 09:41 PM   #1
Need some recommendations.
I have a 2013 f250 powerstroke. I would like to upgrade to a toyhauler with 12 foot cargo area seperate from rest of camper. Any recommendations?Pin weights seem to be an issue with all the ones I look at.
LSUTiger is offline   Reply With Quote
Old 07-16-2015, 09:57 PM   #2
Assistant TP Supervisor
LSU, we need a little more information to help. 4x2, 4x4, box length, rear differential etc
B and B is online now   Reply With Quote
Old 07-17-2015, 08:35 AM   #3
Pin Weights get better when you load a toy in the back at least on my 27rr. You might look into this model. Pin weight is right at 950 when loaded with my 950 pound Victory.
Rhoadzie is offline   Reply With Quote
Old 07-17-2015, 11:30 AM   #4
Little more info on my truck.... 4x4 crew cab, Payload 2,145 lbs, 3.31 rear end, 10,000 gvwr package, standard 6 foot bed...
Old 07-17-2015, 12:27 PM   #5
Jeff Auton's Avatar
Look at the XLR 300x12. Your f 250 will handle it fine. Good luck.
Jeff Auton is offline   Reply With Quote
Old 07-17-2015, 05:53 PM   #6
X2 on the XLR. Call Lori Carte @ RV Wholesalers.
Chevy 3500HD Dually
XLR Thunderbolt 417amp
RZR XP 4 1000
TexasFamily is offline   Reply With Quote
Old 07-17-2015, 06:07 PM   #7
ferguson65's Avatar
I've got a Palomino Puma 351THSS. 12' garage, 14xx# pin weight and didn't break the bank................ Maybe worth a look to you depending on what you want.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 10-25-2015, 06:53 PM   #8
Have 2016 Spartan 34x with Ford F-250 diesel no issue pulling it 5th wheel weight 14000 net weight with all option I put in did over 5000 miles no issue
2016 Spartan 1234X Trail-Air Pin Box...thermo windows...12 cu.ft frig....3 seasons patio door
2011 Ford F-250 Super Duty Power Stroke King Ranch 4X4 diesel
Pierre Allard is offline   Reply With Quote
Old 10-25-2015, 07:21 PM   #9
Is that the 1234x?
Old 10-25-2015, 07:34 PM   #10
We also recently upgraded toyhaulers to the Vengeance 320a model, the hitch weight of our unit is 2882. Good luck with your search.
Brian
2017 GMC Sierra 2500 Duramax L5P
2016 Forrest River Vengeance 320a.
LB TN is offline   Reply With Quote
