Old 10-01-2014, 11:21 AM   #1
New 5er Toy Hauler - What Wheel/Tire Essentials?
Hey all --
My wife and I just bought a new Shockwave 5er this past weekend. We've never had one of these before. We went to Camping World and got a number of items for the inside, etc.
One thing that I don't know about are the needs of wood blocks, those things that go between the tires to keep them from moving, etc. I saw that you can buy bright orange or yellow stackable blocks. I'm guessing that you want to put the landing gear under some sort of block? Why? Also, do I need to get blocks for the tires as well to help level the unit if it's not on flat ground? It's a dual axle trailer so I'm not sure if that is difficult to put blocks under both tires on one side or not.
What about covering the wheels? I see a lot of people cover the wheels and tires. Why is that?
Anything else that I may be missing in regards to this type of stuff?
Thank you,
-Allistah
Allistah is offline   Reply With Quote
Old 10-01-2014, 11:33 AM   #2
Oaklevel's Avatar
On soft ground you may want to put 2 x 10s under the landing gear for more surface area. I use 2x 10s under the wheels to level it is very easy you need a carpenters level (or other level). Just pull the trailer onto the 2xs )
The lego levelers are nice but for me 2x 10s are much cheaper & if you loose them no big deal
You need wheel chocks to keep the trailer from moving or rolling off........
Been discussed just do a search.......about leveling. The trailer needs to be side to side level as well as front to back level.
Covering the wheels in storage is a good idea the sun is your enemy
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 10-01-2014, 11:46 AM   #3
Thanks for the reply. Are those things that bind between the wheels to prevent them from moving bad for the axles? I would think that putting pressure side to side like that where it's not meant could be bad for them over time? I guess when you put tires up on 2x10s, you can really use the wedges that go behind the tires. I guess if you use the thing that goes between the tires you should have one on both sides?
Old 10-01-2014, 06:12 PM   #4
Congrats on the fifth wheel. Mine is being delivered tomorrow. Search the forums for answers to many of your questions. I spent months searching all the RV forums I could find and found answers to questions that I didn't even know to ask yet. It was a lot of time spent reading a ton of posts but time very well spent. My dealer is great and has been doing this for years and I found things that he hadn't heard of. Good luck with your new toy hauler
sndtowne is offline   Reply With Quote
Old 10-01-2014, 06:18 PM   #5
Thanks.. I've been searching and learned a lot about chocks and all that. I'll probably start out with a couple sets of 10 of the orange blocks and the tire chocks that go with them as well as the flat caps. Will also get a set of the deluxe BAL tire chocks to minimize movement when moving around inside. I'm sure there will be a lot more to learn about this thing once we get it.
Old 10-01-2014, 06:29 PM   #6
Ford Idaho's Avatar
Congratulations on the new unit and welcome to the forums from SW Idaho.
I cover my tires with covers from Walmart online.
The covers are to protect the tires from UV damage.
What Causes Dry, Rotted Tires? | eHow
Classic Accessories RV Wheel Covers, White - Walmart.com
Be sure you get the right size for your units tires.
Old 10-01-2014, 06:30 PM   #7
Lol, I'm in the same boat. It's my first fifth wheel so let the learning begin.
Old 10-09-2014, 05:32 PM   #8
HarrynSally's Avatar
Remember the yellow block only fit yellow covers ans so on.
And Orange blocks only go with orange covers, etc.
They don't interchange.
HarrynSally is offline   Reply With Quote
Old 10-09-2014, 08:16 PM   #9
wbdavey's Avatar
I suggest only buying the minimum amount of stuff until you've used the TH some. I prefer boards over the plastic blocks and with a TH you have room to store them. There are lots of good products, but you don't need ALL of them! My previous trailer was a 43 foot 5th wheel TH that was used as a winter home in Fl. IMO, if the trailer weight is supported on rubber tires, you will always have some motion. For long stays I carried large cribbing (big wood blocks) and 4 screw jacks under the frame in addition to all the other factory installed jacks.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
tire, toy hauler, wheel, 5er
