Old 01-03-2014, 10:24 PM   #1
Flojos89's Avatar
Onan Generator
Generator on Stealth Toyhauler turns on but will not stay on..
Flojos89 is offline   Reply With Quote
Old 01-03-2014, 11:03 PM   #2
These are the things I would check first. Do I have enough fuel in the tank. Is my gen. Oil level above the add mark. Is it really cold and I need to start it several times to warm it up some. Did it run OK the last time and how long ago. Did the gas go bad? Do I have things turned on that are placing a load on gen. when trying to start.
I'm sure others will have more ideas. I was just thinking of simple things to check.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 01-04-2014, 01:12 AM   #3
wyo700's Avatar
I know that some Onan gens had fuel pump problems. That could possibly be it. But all the other suggestions would be first.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 01-04-2014, 10:21 AM   #4
Flojos89's Avatar
I'll do the check list and see what i come up with...
Old 01-04-2014, 12:02 PM   #5
Mike001's Avatar
My Onan generator's fuel pump died after 17 hours on it. We were dry camping in Dover at a NASCAR race. It was 90 degrees outside! I guess we were lucky it died with just 1 day left. Onan was pretty good about it, I called on a Monday, brought the RV to their shop, and they had it fixed the next day. No charge, under warranty.
Mike001 is offline   Reply With Quote
Old 01-04-2014, 12:15 PM   #6
Flojos89's Avatar
We tried spraying starter fluid and it would stay on but die like it was starving for gas...
Old 01-04-2014, 12:19 PM   #7
Mike001's Avatar
Best way to check the fuel pump is to take off the gas line that runs to the carb, try to start it, if no gas, than it is probably the pump. That's how i diagnosed mine at home before driving to the dealer.
Old 01-04-2014, 01:21 PM   #8
Flojos89's Avatar
Thanks check that out too
Old 01-04-2014, 02:52 PM   #9
ourflat's Avatar
Download user manual from their website and run through their troubleshooting steps in the back of the manual. When was the fuel filter changed?
Frank
ourflat is offline   Reply With Quote
generator
