Old 08-05-2017, 09:41 AM   #1
Parallel generators not powering TT.
I have 27HFS that had a champion gen by and it died. I purchased these two Yamaha 2000 watt generators to run on parallel. I turned everything off in the trailer and when I warm up the generators and plug in just a fan, the fan isn't getting fully powered up.
Is there something that I'm missing? Is there a switch somewhere in the TT that needs to be toggled? I tested the generators with the parallels powering the fan on an adapter 30 amp and they are powering very well. I checked all the fuses and they are good. The TT works normal when plugged into a 30 amp outlet. Is there something wrong with the inverter?
matthewlove444 is offline   Reply With Quote
Old 08-05-2017, 09:50 AM   #2
I'd bet it's a neutral bonding issue. Someone with more experience is bound to show up.
aeblank is offline   Reply With Quote
Old 08-05-2017, 10:18 AM   #3
clr
The new Yamaha's use a paralleling cable arrangement between the two generators to sync them together. Are you using that cable? If so are you sure it is connected correctly?
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-05-2017, 10:24 AM   #4
Scoundrel
HangDiver's Avatar
Do you have an EMS hardwired on your TT?
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 08-05-2017, 10:34 AM   #5
Yes and I tested the parallel using a 30 amp/110 adapter on my fan and the generators work great.
Old 08-05-2017, 10:34 AM   #6
EMS?
Old 08-05-2017, 10:36 AM   #7
Ok thank you
Old 08-05-2017, 10:39 AM   #8
Scoundrel
HangDiver's Avatar
Originally Posted by matthewlove444 View Post
EMS?
Electronic Monitoring System..... if it senses and open ground on your generator it will not allow power from your Yamahas into the camper.
Old 08-05-2017, 10:53 AM   #9
Scoundrel
HangDiver's Avatar
Open ground
Old 08-05-2017, 12:13 PM   #10
You might need the Progressive bonding neutral - ground plug. About $15
robbdrell is offline   Reply With Quote
Old 08-05-2017, 12:16 PM   #11
Awesome, I think that's it my friend. Thank you.
Old 08-05-2017, 12:16 PM   #12
Ok cool thank you.
Old 08-05-2017, 02:29 PM   #13
Handy2016's Avatar
Make your own, real quick and easy. Just run a jumper wire from white(neutral) to green(ground) screws on a male plug. Then just plug it into unused 120v receptacle on your gen set.
Handy2016 is offline   Reply With Quote
Old 08-05-2017, 03:04 PM   #14
Headed to THD right now.
Old 08-05-2017, 05:07 PM   #15
Cajun Style's Avatar
Cajun Style is offline   Reply With Quote
Old 08-05-2017, 05:10 PM   #16
http://noshockzone.org/generator-gro...utral-bonding/
This will help a lot.
Old 08-05-2017, 05:46 PM   #17
Originally Posted by Cajun Style View Post
Didnt work. AC kicks in for about 10 sec and then power shuts off. I have no other appliances running. I even have the fridge on gas.
Old 08-05-2017, 05:49 PM   #18
Is this something that comes with the TT or is it added?
Old 08-05-2017, 05:52 PM   #19
dbledan's Avatar
I think your parallel cable is not connected all the way. Check that first.
Does the overload light kick on for the generator?
Flip all breakers off except for A.C. the inverter may be running to charge the battery. You will also want to set the stat higher than a giant temp or just turn on fan only first. Once running well then engage the ac by lowering the temp or turning on a.c..
If overloaded you may need a hard start capacitor for your AC.
dbledan is offline   Reply With Quote
Old 08-05-2017, 07:04 PM   #20
narrowsboy's Avatar
It is imperative that one generated is started first and establishes the second one as the slave. If not you will get an overload condition. I was told this by a Yamaha corporate repersentative. I encountered the same problems. I turned off all breakers in the fifth wheel. Started one generator. Let it warm up and go to Eco mode. Then I started the second unit. I then turned on the ac breaker. Everything worked fine after that
narrowsboy is offline   Reply With Quote
generator, power
