Old 03-15-2012, 08:46 PM   #1
recon33alpha's Avatar
potential fluid leaks
What does everyone put down in case of a fuel leak from one of the toy's in route? I assume the vapors would be bad and hard to stay inside after a leak. Any help would be appreciated.
Recon
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
recon33alpha is offline   Reply With Quote
Old 03-15-2012, 09:23 PM   #2
PrairieBoy's Avatar
I usually use sawdust or cat litter for oil and other leaks or spills. Not sure about a gas leak.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
2012 Dodge Ram 1500 4X4 CC Outdoorsman
PrairieBoy is offline   Reply With Quote
Old 03-15-2012, 09:42 PM   #3
We have oil absorbant pads at work. You could use something like that with a couple small pieces of duct tape to hold it in place.
rkswyo is offline   Reply With Quote
Old 03-15-2012, 09:47 PM   #4
TURBS's Avatar
Product called pig mat
Old 03-15-2012, 10:33 PM   #5
caper's Avatar
You could put a boot tray below the tanks. Have an absorbent material in the tray to catch any spills. The tray can be removed once you get to your destination.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-16-2012, 11:30 AM   #6
This is all meant in fun, couldn't resist,
We don't haul Harley's, so we don't have any leaks.
Seriously,
A pad, or some newspaper held down with bricks. Then the bricks can be used under you jacks, or for wheel chocks.
You could also get a piece of scrap carpet, cut like a runner, so both wheels of the bike would hold it in place.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-16-2012, 12:45 PM   #7
TURBS's Avatar
called my local www.sadlerpowertrain.com and was told a lower plate could be purchased.
he said by time you buy the parts to fix you can buy a rerman ad-9 air dryer for less than 200.00
I am only assuming you have an ad-9 dryer .
also Bendix AD-9 Air Dryer | eBay
Bendix Replacement AD-9 Truck Air Dryer AD9 Semi-Truck | eBay
or
Bendix AD-9 Air Dryer "LQQK" Remanufactured | eBay
Old 03-16-2012, 10:13 PM   #8
I'm hauling quads, but seriously the harley joke was funny, lmao. I just got the hauler home today, so I haven't even had a toy in it, was just trying to prevent a future problem. I don't have a seperate garage, the quads go into living space. We have pigmat at work, I'll "sneak" some out, along with having our welder make some small catch containers, custom to fit under the atv's. Thanks for all the input. I'm sure I will have a ton of other questions. Today was the first time I've ever pulled such a long wind sock, about an hour into it I learned real quick to steer slightly away from semi's running 75 mph, when they passed it wanted to suck me in, then spit me out. I have wd hitch but thinking maybe I need an anti-sway control device as well. Not to mention the 15-20 mph wind gusts. It was a learning experience for sure.
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
