Old 12-17-2018, 08:38 PM   #1
Primetime Fury forum
Was wondering if this particular line was in limited production? I note that there are very limited posts in regard to the Fury's and since there is not a sub-forum, does this line fit under one of the existing sub-forum's? I have a 2016 - 2910. Any info appreciated. Thanks. R.
RogerWo is offline   Reply With Quote
Old 12-18-2018, 09:09 PM   #2
udy2554's Avatar
Mine is a 17 2910! Id love to see, hear more too!
udy2554 is offline   Reply With Quote
Old 12-24-2018, 08:09 AM   #3
I have 2017 Prime Time Fury 2910. I would also like to see more activity.
ijon is offline   Reply With Quote
Old 12-25-2018, 11:32 AM   #4
2018 Prime Time Fury 3110 - Nov. 15, 2018
We just purchased a 2018 Fury Model 3110
debilee is offline   Reply With Quote
Old 02-05-2019, 08:06 PM   #5
I have a 2016 Fury 2910. We have had a few issues with it and Prime Time was quick to respond and fix it under warranty. It would be nice if there were more posts about the Fury line to help with troubleshooting or just general info.
MarcMachine is offline   Reply With Quote
Old 02-05-2019, 09:10 PM   #6
Would like to know what you other Fury owners are using as far as tow vehicle and hitch set Up's. I have a 2016 - 2910 (on board gen.) and tow with F250 with class IV hitch and equalizer. thanks I'm finding that the hitch weight is very close to Max (1250 lbs). Dry weight is spec at roughly 950 lb and this apparently does not include generator weight? So, by the time you add battery weight and propane?
RDW
Old 03-26-2019, 11:22 AM   #7
udy2554's Avatar
I have a similar setup!
Im towing with an 18 Ram Power Wagon! Equalizer WDH, Ultimate 5000 Air Bags with on-board air and remote!
Im happy with how it tows!
Old 04-05-2019, 10:05 PM   #8
I have been towing with the E2 round bar hitch rated at 10000 lb with 1000 lb bars. This was with the trailer when I purchased it and seemed to be marginally ok. The bars I'm sure we're over max probably without any interior living additions. When I loaded the trailer I was careful to keep most items to the hauler area. I will be shortly upgrading to a E4 14k hitch with 1400 lb bars, so it will be interesting to see what the difference in towing will be.
