Old 01-17-2019, 02:51 PM   #1
satellite options
I have Dish network at my home, i want to use ii in my 5'er, theres a few options for the Dish, what has been working for others? im thinking of going with the portable set up.
2018 Puma Unleashed 373 QSI Toy hauler Fifth wheel
Firedude26 is offline   Reply With Quote
Old 01-17-2019, 03:24 PM   #2
Tx2Stepn's Avatar
I use the Pathway X2. I have a step stool and place it on my roof from the patio when I set up. Works great for me with the Wally. It gives me access to E and W satellites. My sister has the older receiver and a King Tailgater and loves it. It is lighter than the Pathway but she only has access to the W satellites. I have seen that the newer version has access to both satellites. Hope that helps.
2012 Ram 3500 Cummins - 2018 Wildcat 29RKP
2000 Ford F-250 V10 - 2017 Catalina Trailblazer 26TH
2007 Rockwood Freedom Popup
Tx2Stepn Yorkies
Tx2Stepn is offline   Reply With Quote
Old 01-17-2019, 03:35 PM   #3
NMWildcat's Avatar
Portable sat dish is great. We have used our older tailgater and 211k all over the country.
Too much is made of Eastern arc vs Western arc satellite coverage. Ours only does Western and works everywhere we have been, coast to coast. If you get too far north and east (like Maine), you may have problems getting the HD satellites, but the SD satellites are good. No biggy.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 01-17-2019, 03:38 PM   #4
lmiken's Avatar
I have two Dish 722 receivers at home (since I like to record when I'm out). I take one receiver on the road with me. I started out with just a Dish antenna which is fairly easy to set up once you get used to it. I recently got a winegard G3 antenna I put on the roof (only antenna which worked with the 722 receiver). The Dish antenna receives all 3 satellites (110, 119, 129 western arc satellites). The winegard gets all 3 satellites but you can only watch 1 at a time (the 722 receiver can do 2 channels at a time; watch 1 and record another; with the right antenna). So figure out what receiver (and setup) you have/want and make sure the antenna will work with it.
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
lmiken is offline   Reply With Quote
lite, satellite
