Old 08-16-2016, 09:47 AM   #1
Side by side hyperlite
Hey guys I'm new to the whole toy hauler thing. I was wondering if anyone on here had a hyperlite 29 hfs and if so if it would handle a side by side vary well? I have read some places the axles on them are not the greatest. Just looking at all the possibilities before I buy one. I'm looking to put a wild cat sport in it. They weigh round 1100 lbs. Thanks
Turtle08 is offline   Reply With Quote
Old 08-16-2016, 02:58 PM   #2
egladden's Avatar
The garage is rated for 1600 pounds and I hauled a Street Glide and a sportster side by side and could walk around them.
egladden is offline   Reply With Quote
Old 08-18-2016, 12:32 PM   #3
WolfWhistle's Avatar
Turtle, I have not had a side by side in mine, but why not? A 29 might have 27xx cargo capacity, which is kind if low, but how you use it is up to you. if most of that is in the garage, I would be concerned the tongue weight could be too light. I have an Excel weight calculator tool that has shown reason for the concern. My TH came new with a sticker that said the toy bay limit was 2000# and you could add water to the fresh tank to compensate, but it could push you over GVWR. If you stay below the gross weight and balance your load the 4400# axles and D rated tires will be under there max, if only barely. The 29's garage length inside is right at 10 feet. Also, watch your height... can't remember for sure but mine, with bed is about 5'11"
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
