Old 12-01-2013, 05:43 PM   #1
Sierra axle info help
I have a 2004 forest river 5th wheel sierra. I have been going through tires every single time I go out! I have had wheel lugs shear off, and have even had the rims separate at the weld at times. I have looked at the axle tags, and all it says is:
Model D 50
DATE 229402
TLR 375 in
6000 lb
Hayes axles
my trailer weighs approx 14,000 lb.
any ideas on what is really causing this problem?
oifoef0809 is offline   Reply With Quote
Old 12-01-2013, 05:46 PM   #2
Herk7769's Avatar
Model D 50
DATE 229402
TLR 375 in
6000 lb
Hayes axles
Who does your maintenance?
Have you weighed it recently "ready to camp"?
HAM CALLSIGN - KC3FFW
Old 12-02-2013, 01:31 PM   #3
I do most of the maintenance. ASE master tech. but that really doesnt mean anything lol. I keep the brakes, lubes, air pressure, all current and properly adjusted.
Empty, with approx 8 gallons of fuel on board, but with empty water tanks, it weighs in at 13,755 lbs.
the tires currently are load rance E, but when I get a blowout, which is every time I take it out, the other tires are HOT to the touch! I have even broken all of the original leaf springs, but have since replaced them with a heaver duty set.
Old 12-02-2013, 01:32 PM   #4
and by the way, the axle tag says D 60 not the D 50 as I miss typed prior. they are 6000 lb axles
Old 12-02-2013, 01:41 PM   #5
Phat Phrog Stunt Crew
awwall's Avatar
Just a wild thought. Have you checked the "trueness" of the axles? Are they running straight. Blowing tires, shearing lug nuts, tires running hot, sounds like something is not aligned correctly.
Just my 2 cents
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
axle, sierra
