Old 03-15-2015, 08:06 AM   #1
Smoke alarm battery.
My smoke alarm is chirping. Is is the same type as the house smoke alarm? It simply needs a battery? Does camper smoke alarm batteries wear out sooner since the camper when parked has battery power turned off? Or doesn't it matter?
laurajean is offline   Reply With Quote
Old 03-15-2015, 08:18 AM   #2
NKARENG's Avatar
Yes it is. I'm replacing mine today. At the end of the season it started chirping also. Wouldn't hurt to always change out batteries like you do in your home. I don't think it has anything to do with power not hook up to it. They just die.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 03-15-2015, 08:30 AM   #3
Oakman's Avatar
I replace the batteries in both the smoke alarm and the Carbon Monoxide detector at the start of every camping season.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-15-2015, 08:32 AM   #4
Flybob's Avatar
The smake alarm is a stand alone device and is not connected to the camper battery. The battery probably has a slightly shorter lifespan due to the temps in the RV vs your home, but appear to have a much shorter lifespan as the voltage drops with the temp and a weak battery will be noticed sooner in the RV vs in a heated home. The other problem is that the battery can go dead during the winter ( non use months) and stop chirping before you hear it. You now have a non working detector and are not aware of it. Best choice is to replace battery at the start of each camping season.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-15-2015, 08:33 AM   #5
PhoneDude 8289's Avatar
X2 Oakman
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
battery
