Old 10-15-2016, 06:51 PM   #11
northstar1960's Avatar
Originally Posted by HarrynSally View Post
Doing mine now, lots of work!
You added the correct track , gives you some lift , but the wet bolts for the equalizer will be to short . if you find wet bolts that are long enough let me know ! i could use 4 .
northstar1960 is offline   Reply With Quote
Old 10-15-2016, 07:06 PM   #12
If you don't have a drill press or lathe to make them yourself, you can take the longer bolts to a machine shop and have them made. I made my own on our racecar trailer.
Old 10-16-2016, 11:34 AM   #13
no no metal lathe , i would not trust self made wet bolts . the hardened steel would be very hard to drill and i standard bolt i would not trust once drilled . i just installed the brass bushing and greased well should last for several years like that .
the problem is with the mixing of parts from dexter axles to the lippert correct track . one does not work well with the other when looking to add up grades and the correct track system is really a joke to begin with
suspension
