Old 03-18-2017, 10:14 PM   #1
JJaxon's Avatar
Tailgate hits the jack handle - Fix
I completed this project today and made a quick video to show the results of my simple fix.
JJaxon is offline   Reply With Quote
Old 03-27-2017, 11:44 AM   #2
Think I'd prefer an electric replacement without a handle
rblack22 is offline   Reply With Quote
Old 03-27-2017, 11:51 AM   #3
Austintatious's Avatar
How much did the welding shop charge you?
2016 Clipper 17FQ
2016 Ram 1500 EcoDiesel
2015 Jeep Wrangler Unlimited
Austintatious is offline   Reply With Quote
Old 03-27-2017, 01:51 PM   #4
Didn't really need one for my camper, but here's my solution for the boat trailer
One More Time Around: Electric Boat Trailer Tongue Jack
jeffnick is offline   Reply With Quote
Old 03-27-2017, 03:26 PM   #5
JJaxon's Avatar
They didn't charge me. They cut it, cleaned it, welded it, ground it, and handed it back. Can't complain about that, it works great.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2018 Carbon 347 toy hauler
Old 09-06-2017, 08:04 AM   #6
JJaxon's Avatar
To replace the hand crank with electric, I would have to move it's mount back several inches because the motor head is much bigger than the standard tube and handle. Tried to rotate to change, but the frame only accommodate this position without frame modifications. Why can't the manufacturers see this issue and move the jack back when building?
John
Old 09-11-2017, 11:01 PM   #7
jjgabe's Avatar
JJaxon, love the Navy Vet sticker! I hit 24 years this month and still going.
jjgabe is offline   Reply With Quote
Old 09-12-2017, 10:13 AM   #8
JJaxon's Avatar
Thank you for your service to our country.
John
Old 09-12-2017, 10:27 AM   #9
We had the same problem with the jack post hitting the center of the tailgate on our Ford F150. We replaced it with this jack: The Ultimate Jack | A-Frame Trailer Jack at its Finest!
lonewolf465 is offline   Reply With Quote
Old 09-12-2017, 10:55 AM   #10
good idea, ... I solved the same problem with Jack-E-Up, but your solution works just as well, ...
fella10 is online now   Reply With Quote
Old 09-12-2017, 11:20 AM   #11
Georgia Rally Coordinator
aceinspp's Avatar
If there is a 3 bolt hole pattern on the jack you should be able to rotate so its ether right or left side of tongue . You can mount the electric also to be rotated away from the vehicle. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 09-12-2017, 11:47 AM   #12
JJaxon's Avatar
There is a 3 hole bolt pattern, but it is not equally spaced, ie, 2 legs are longer than the 3rd, just enough to not fit properly. The nuts are welded to the bottom of frame So it just doesn't work. So, I went with lengthening the handle instead of butchering the frame or mount base of jack.
John
Old 09-12-2017, 12:05 PM   #13
aceinspp's Avatar
Thanks I was able to rotated mine as holes lined up. Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 09-12-2017, 12:37 PM   #14
The bolt patterns are not symmetrical and can't be rotated 45 degrees and lined up. I couldn't rotate my manual crank on my 2007 and I couldn't rotate my electric on my new one.
TheWolfPaq82 is offline   Reply With Quote
Old 09-15-2017, 09:25 AM   #15
Retired JSO's Avatar
I mounted an electric jack on mine. The jack head sits higher thus out of the tailgate arc.
Retired JSO is online now   Reply With Quote
