Originally Posted by RVDon
I went with the Sailuns S637 on my 39R12 at 95psi and put little over 5,000 miles last year with know issues. I run a TPMS on mine, on hot days at 65 mph the psi will never go over 107psi.
Just remember you have to change your valve stems with higher psi rating.
Mine came with 7,000lbs axles
Check out Simple Tire.
After my initial incident we saved up for a TPMS as the next 'big' purchase. We then slowly bought one S637 at a time until we had 7 and got them installed. Most were from Simple Tire but we did buy from a couple of other vendors as well. Peterson's Tire in Blanco Texas did the work and they carry the Sailuns in-stock and highly recommended them. They are certainly good ol' Texas boys who cut me a great deal and didn't nickle and dim the process. When doing the work I also had them install all metal valve stems with high pressure schrader valve.
I'm glad yours came with 7,000lbs axles installed, really wished mine had them.
