Old 02-04-2014, 06:39 PM   #11
Infractee
GeoFish,
That is the purpose of the WD feature of a WDH. It takes the weight off the tongue and moves it forward thru leverage to the front of the truck, unloading the tongue weight both forward and aft to the trailer wheels while leaving an appropriate amount on the hitch itself, depending entirely on your adjustments.
RhoZeta is offline   Reply With Quote
Old 02-11-2014, 12:30 AM   #12
1l243's Avatar
You did not give much informaton on your truck. Are you sure that the 11,300lbs is not GCWR Gross Combined Weight Ratio? This would be your truck and trailer total weight?
With your 27ULSBS fully loaded and your truck loaded I would guess your GCWR would be around 15,000 to 17,000lbs?
Does your f150 have a towing pkg ie....Heavy duty cooling, trans cooling, tow shift trans?
The Work and Play 275ULSBS is a nice rig. Your right about the gen and propane tanks adding to the TW significantly. I don't think it's unusual for the manufacturer to assume you going to be hauling 1000lbs or more when using the trailer they are designed that way.
Back to your truck. I would at least upgrade the hitch. The OEM hitch on my Super Duty was just 10,000 I upgraded to 16,000 and it does not cost that much for the extra assurance. I would also ad sway control. I run two friction bars one on each side with WDH. Airbags?
I found the 11,300lb specs you stated you must have a ecoboost? Impressive towing. Do you know what the GXWR is?
1l243 is offline   Reply With Quote
Old 03-24-2014, 06:28 PM   #13
You can never have too much truck!
Ultraboy is offline   Reply With Quote
Old 03-24-2014, 06:38 PM   #14
Mddle of the Rd Extremist
MeepMeep's Avatar
I second that!!
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 03-24-2014, 07:50 PM   #15
Go with a one ton dually you will never regret it.
Pitcrew18 is offline   Reply With Quote
Old 03-24-2014, 10:01 PM   #16
No doubt! My latest is a 2012 f-350 turbo diesel DRW.
Old 03-28-2014, 08:42 AM   #17
BeeGee's Avatar
once you get an f350 you will never even think about weighing your th again. Load it to the roof and youll never know the difference
Sent from my SCH-I545 using Forest River Forums mobile app
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 03-29-2014, 03:45 PM   #18
Just Love to Camp
TheFordes's Avatar
We ended up bumping to a F450
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 05-11-2014, 12:52 AM   #19
Size does matter, we tow our 38 foot fifth wheel toy hauler with a Freightliner FL-60 Sport Chassis, you can never have to much truck
my posts are for entertainment purposes only and may not be constituted as scientific, technical, engineering, or practical advice. Information is believed to be true but its accuracy and completeness cannot be guaranteed / or deemed fit for any purpose
jeepoholic is offline   Reply With Quote
Old 05-31-2014, 12:10 PM   #20
camojeeper's Avatar
We have an 03 F350 with 4.10 gears and a 7.3. It tows our F37 FTH like a dream! 2,200lbs of pin weight 15,000 lbs of 39.5' toy heaven.
GCVW is 24,980lbs. As was said above you can never have to much truck
Steve
Tow Rigs 96,99.5,03 F-350's all with the mighty 7.3 PSD
Hauler F37SP
camojeeper is offline   Reply With Quote
towing, toy hauler
