Old 04-06-2016, 11:58 AM   #1
Wobbles's Avatar
Triple axle leveling side to side
I am asking for a buddy that just bought SOB 5er TH, without the high end level up system.
He made his first trip using boards under the tires.
So, How do you level your triple axel?
Wobbles is offline   Reply With Quote
Old 04-06-2016, 11:58 AM   #2
Fulltime family RVer
Boards/Lynx Levelers under all 3 tires.
Old 04-06-2016, 11:59 AM   #3
Kenny kustom's Avatar
How many tires do you have??
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-06-2016, 12:21 PM   #4
F350TH's Avatar
6 on a triple axle, usually...
2015 XLR Nitro 39DKS5 Toy Hauler
Towed by 2016 Ford F350 CCLB DRW 6.7
F350TH is offline   Reply With Quote
Old 04-06-2016, 12:34 PM   #5
I meant for Wobbles' friend. Support/lift all 3 tires on each side.
Old 04-06-2016, 12:50 PM   #6
Ah ...
2016 Sabre 36QBOK
Old 04-07-2016, 06:40 AM   #7
Keystone's Avatar
I use the Anderson drive on auto level wheel chocks. Real easy to use even if you are alone. Link is here
US Army, 1979-1990 95BZ6
Keystone is offline   Reply With Quote
Old 04-07-2016, 10:16 PM   #8
We use boards under all tires on low side. Okay, Let me rephrase that. My husband uses boards. I really need to learn this stuff because I want to go by myself sometimes.
Dawn & Jeff
2003 F350
2012 XLR Thunderbolt 35X12
2008 Vrod Trike, 2010 DynaGlide
2 non-traveling Standard Poodles, Ralph & Smokey
dawn52627 is offline   Reply With Quote
Old 04-11-2016, 10:07 AM   #9
I don't have triple axles, but I have used those anderson camper levelers and they are the best thing ever. Only a couple of cases where I had to have a nice long 2x6 to put under the tires first, then use the levelers on it, due to wet soggy ground.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 04-11-2016, 10:34 AM   #10
yetavon's Avatar
We have a 2x6 long enough to go under our wheels with 45 angle on the ends.
1) Park where we want to setup.
2) 2 foot level across the floor, measure how much out. (say 3/4 inch)
3) Multiply by 4 will give how much out in the trailer width. (3 inches)
4) Move forward or back and build a 3" tall platform with the 2X6
5) Move the camper up on the platform and install the X-chocks.
Perfect side to side every time. Have even set up on an incline and made the platform level front to back.
Our block collection contains 1/4" to 3 1/2 (4x4s) all cut to the same length to construct whatever we need.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
leveling, axle
