Old 06-01-2017, 04:16 PM   #1
Tim Coltrain's Avatar
Tripod 5th wheel
I know some of you use the tripod system on the king pin to stop shaking or movement. What did you find so great about it. What did it do to make you a happier person. I have not bought on as of yet, so when I came home this past weekend I took my shop tripod with my 8 ton jack and put what I believe to be more pressure than a typical tripod. I asked the wife to lay on bed while I walked around and she said she could still fill my every movement. So what is so great about these tripod systems. Am I missing something?
Tim in HOT NC
Tim & Rita Coltrain
2012 Chevrolet 2500 Duramax Crew Cab, Allison Tranny Has now been replaced by a NEW 2018 LP5 Duramax 2500 Allison Tranny.
XLR Thunderbolt 2016
Tim Coltrain is offline   Reply With Quote
Old 06-01-2017, 04:48 PM   #2
BandJCarm's Avatar
I have shunned them as most folks say they are a waste of money.
However.........I just talked to 2 folks that have washer and dryers that swear by them. I am about to get a washer and dryer and if they shake the trailer these might help. However, I have no direct knowledge. Interested in the responses here.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-01-2017, 05:09 PM   #3
Casey & Carolyn
Casey r's Avatar
We use JT Strongarms and Xchocks. Made a world of difference.
Casey r is offline   Reply With Quote
Old 06-01-2017, 05:14 PM   #4
Dakota EV's Avatar
I have a washer & dryer in our 5th wheel and we can tell the difference when we use our tri-pod. also I put a lock on my tri-pod and it just add another layer of security for our 5th wheel when we are gone. I know that the lock can be cut but at least it will slow somebody down if the try it.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 CD
TMPS for Camper & TV
Days Camped for 2017 - 128
Days Planned for 2018 - 42
Dakota EV is offline   Reply With Quote
Old 06-09-2017, 08:44 AM   #5
Ok. I took the advise of those who thought the tire brake and 5th wheel tripod would make difference. Well it made a big difference. I was impressed. Camp on.
Tim & Rita Coltrain
Old 06-09-2017, 09:12 AM   #6
Iwannacamp's Avatar
Great... I guess I need a tripod now. LOL I have a 5th wheel with JT strongarms on the front(long story) and X-chocks and plan to add the mid-ship stabilizers(if I live long enough). I didn't really notice much with Xchocks, but DW said she did...good enough for me. The JT's DID help a lot. Camp on!
I have to remember one thing... It isn't on a slab!
2017 Puma 297RLSS
Old 06-09-2017, 09:30 AM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
I prefer the combination of items, JB strong arms, Bottle jacks under the mid frame, electric stabilizer at the rear and wheel chocks. But at the end of the day we still feel some movement, just not a much.
donanddona is offline   Reply With Quote
Old 06-09-2017, 09:33 AM   #8
Islander's Avatar
I do have and use a tripod on my 5th wheel and find it helps a great deal for the front 'wiggle' when someone walks around or from strong wind.
However, if I did not already have one I would use the alternative like the 'Stabilizing Bar' from Bal-Products <link or JT Strong-arms. I have the BAL stabilizing bars on my rear scissor stabilizer jacks and found a great difference in removing the 'rear wiggle' when someone comes aboard or walks around inside.
I am contemplating installing them on the front legs as well. Then I wouldn't need the tripod.
I also use my wheel X-chocks (that I made) which helps with the bounce and back-n-forth movement. (see picture)
I plan on adding a step support or two because my wife tells me she knows when I leave, or come back, to walk the dog early in the mornings.
With what I am using right now to stabilize is working pretty good.
There are others who found the tripod to be worthless or cumbersome.
You will have to play around with applying the right amount of pin-weight to be stable, but then use caution not to apply too much weight.
I found that on some types of ground I will apply a little more weight after a day or two as it settles in.
I will have my rig at near level (slight front high) bring up the tripod tight to the pin-box bring in all the chain slack (if that is the type you are using) then lower the jacks to put some strain on the chains.
Test by pushing on the front-side of the 5th wheel .... should be no wiggle.
"Dakota EV"... talked about using a lock... good idea.
What I always feared was some joker coming along and raising or lowering my landing jacks via the exterior rocker switch ... So I installed a keyed "power-cut-off switch" that I installed just inside of the front storage compartment....see picture.
I hope this helps
Islander
Name:	Wheel Chocks 2.jpeg
ID:	140657   Click image for larger version
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 07-09-2017, 04:03 PM   #9
Update
I just wanted everyone to know that July 4th we tried the tripod with wheel locks and NO MORE MOVEMENT. Very Pleased. Thanks for everyones help in this matter.
Tim Coltrain in HOT NC
Tim & Rita Coltrain
5th wheel, wheel
