Old 06-01-2016, 04:01 PM   #1
TV issues
Guys my new Vengeance 398 v seems to have some issues as it relates to connectivity and I wanted to run it past the brain trust before I dig into it.
My unit is equipped with a Hd antenna and it works great when in range, however it only works on the main cable outlet in the living room, bedroom and garage receive no signal. This weekend camping allowed for a cable hookup, i connected and did not receive any signal anywhere, neighbors all worked fine. All proper adjustments were made on tv interface from antenna to cable. There are two cable ports in my docking station and I attempted them both, but received nothing. Any input would be greatly appreciated.
mrh2008 is offline   Reply With Quote
Old 06-01-2016, 04:17 PM   #2
CaptnJohn's Avatar
One is for cable the other for satellite. You will have a button someplace that changes from cable connect to antenna. If one works correct they all should unless a problem at the splitter
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
