Old 03-17-2015, 09:20 PM   #11
That's the dry pin weight. Depending on how you load the rig I bet you will be close to your payload on the truck once you get the family and hitch in there. If you are near the gvwr of the th you will be close I bet. (22% as an estimate of 19500 is 4290 on the pin)
gtsum2 is offline   Reply With Quote
Old 03-18-2015, 10:32 PM   #12
campr-pete
campr-pete's Avatar
pin weight
Don't know how true this is but I was told that if I load the garage at the specs that the toy hauler recommends that the hitch weight will not change by more than 500lbs, they recommend that 2000lbs of the 3450 be loaded in the garage which would be behind the rear tires this equates to about 70% of the load in the toyhauler.
campr-pete is offline   Reply With Quote
Old 03-18-2015, 10:38 PM   #13
campr-pete
campr-pete's Avatar
trucks payload number
My truck has a 4780 payload
Old 03-23-2015, 12:53 PM   #14
chpence1's Avatar
So if you put a bunch of lead in the garage does the hitch weight go down? (Less)
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 03-23-2015, 01:07 PM   #15
It should go down a few hundred lbs
Old 03-23-2015, 09:47 PM   #16
We have a 42 ft toy hauler that we pull with a F-350 DRW and haven't had any real problems, but we did add rear air bags so that when hooked up the truck and trailer both sit level.
the.wilsons is offline   Reply With Quote
Old 03-25-2015, 08:45 AM   #17
Upgrading whats your thoughts?
Like the wilsons, I have a 41' toy hauler we pull with a '12 F-350 dually diesel. With the toys in the back, and fully loaded ready to go (we don't carry more than 5 gallons of fresh water) the 5er weighs 19,500. The max gross is 20,500. This is a triple axle 5er with brakes on a 6 wheels, no problem stopping. We have towed all over the country, through the mountains, etc. with no problems. Fuel milage averages 10-10.5 mpg. You shouldn't have any problems, just select the right 5th wheel hitch. I opted for the B&W turnover ball, with the heavy duty companion hitch. We also added air bags to level it out when loaded.
Good luck, and great camping!
Ultraboy is offline   Reply With Quote
Old 03-26-2015, 04:22 PM   #18
jeff4100's Avatar
I have a 2015 380 amp 42' and pull it with a 2015 2500 gmc duramax with air bags and I don't have a problem at all. Took it down to bike week this year.. Pulled great!
jeff4100 is offline   Reply With Quote
Old 03-26-2015, 08:14 PM   #19
Make and model of the toyhauler in question would be helpful.
taken is offline   Reply With Quote
Old 03-27-2015, 08:13 AM   #20
Taranwanderer's Avatar
The "general" rule here is that for every 2.5# you put in the garage, it lightens the pin by 1#. Of course, things like distance from axles to pin vary from unit to unit and will alter that number slightly, but that's the quick and dirty computation.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
