Old 09-02-2016, 09:33 PM   #1
Hercules Power STR 235/85R16 Tires Vengeance 39R12
Has anybody used these or heard good or bad. My dealer carries these and will replace my 7 E rated tires with these before picking up. $1023.00 for all 7 tires and I keep the brand new used ones with about 400 miles on them.
Hercules Power STR ST235/85R16 Overall Diameter: 31.73 in Fits Rim Size: 16 in Rim Width: 6.50 in Ply Rating: 12 Load Range: F Section Width: 9.250 Max Load Single: 3,960 lb Max psi: 95 lb
Says has a 36 month warranty on defects.
RVDon is offline   Reply With Quote
Old 09-02-2016, 09:50 PM   #2
They also have these too.
Hercules H-901 ST All Steel Commercial Specialty Trailer Tire.
ST225/90R16 14 ply 4079lbs
Old 09-02-2016, 10:55 PM   #3
CaptnJohn's Avatar
Not those but if you want LR F ~~ my dealer will install Carlisle 235/85/R16 LR F 95 PSI for $104 each and make an offer on your OE tires. Carlisle has a good reputation and availability is better than many others.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-03-2016, 03:30 PM   #4
Not sure about those. But something to think of if you want to stay around that price range is a set of Sailuns. They're G rated and have been getting really good reviews. Keystone Fuzions come with Sailuns now.
By the way. Make sure they put on high pressure metal valve stems.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 09-03-2016, 03:33 PM   #5
CaptnJohn's Avatar
m
And make sure your rims are rated for 110# psi. Even 80# psi should use metal valve stems.
Old 09-03-2016, 09:08 PM   #6
I have about 6-8 weeks to figure it out before RV comes in but definitely will get metal valve stems. If I was in NC I'd come by for the Carlisle tires but I'm in PA.
Old 09-03-2016, 10:29 PM   #7
CaptnJohn's Avatar
[QUOTE=RVDon;1308271]I have about 6-8 weeks to figure it out before RV comes in but definitely will get metal valve stems. If I was in NC I'd come by for the Carlisle tires but I'm in PA.[/QUOTE
Any tire dealer should be able to get Carlisle overnight from their wholesaler.
Old 09-03-2016, 11:04 PM   #8
What's the gross weight of the camper they're going on?
I personally would only buy Maxxis m8008 for up to 12-13,000 lbs. Anything much over that and I'd be looking at the Sailun S637 or Goodyear G614.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 09-04-2016, 06:52 AM   #9
I'm assuming they still come with the same wheel as mine. If so, they are rated to handle 110 psi and I "think" 3750 lbs.. Can't recall exactly the weight rating but the air pressure is good.
Do they look like these?
2004 Puma 30FQSS
2010 Sabre 31QBDS
Old 09-04-2016, 07:01 PM   #10
The booklet says 18,000 but it maybe up to 20-21,000 due to axle upgraded to 7K.
Here's the picture of the wheel. Do they already have metal valve stems, I didn't pay attention.
tire, tires, power
