Old 05-17-2015, 06:37 PM   #21
It was primed fri and pump wrked as it should, we got up sat morning and turned shower on and nothing, however everything wrked Friday like it should.
Arkguy29 is offline   Reply With Quote
Old 05-17-2015, 06:50 PM   #22
Witch Doctor's Avatar
Maybe your intake hose to the pump is higher then you think, fill it up and see what happens?....
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-18-2015, 05:37 PM   #23
My pump did the same thing first time using it. The cap for the filter was loose causing the pump to suck air into it. No problems after tightening the filter cap
2013 Cherokee grey wolf 25rr
06 F 250 5.4L gas
03 Honda vtx 1800c
R1campr is offline   Reply With Quote
Old 05-23-2015, 10:46 AM   #24
Is the hose from pump to holding tank just place in there or is there a fitting, it pumps good from antifreeze location but still not from tank. Thank goodness for cwl.
Old 05-23-2015, 11:38 AM   #25
You should have shut off in your FW line, you need to cut that off so the anti freeze will pump. Did you open that back-up and shut off the antifreeze valves. They are all in line. That is way it is on mine but I didn't read or missed what trailer you have...
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-23-2015, 02:35 PM   #26
Yes I shut it off from antifreeze but not pumping good from holding tank. So I think something from holding tank to pump that's blocking it
Old 05-23-2015, 02:45 PM   #27
Oaklevel's Avatar
Sorry for the question but filling the water heater & using the water you do still have water in the fresh tank. You filled it before you left home??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-23-2015, 11:06 PM   #28
Yes I filled it full b4 we left. I like our water a lot better than where we camps water
pump, water, water pump
