Old 05-15-2015, 03:35 PM   #1
Water pump not pumping
New xlr 305 and can't get pump to prime. Just gurgles. Help?
Arkguy29 is offline   Reply With Quote
Old 05-15-2015, 03:38 PM   #2
fonzie's Avatar
Make sure you have enough water in fresh water tank, then check that the anti-freeze input valve is set back to fresh water tank (at the water pump).....
Fonzie
Old 05-15-2015, 03:44 PM   #3
2/3 full, I see 4 valves, 1 b4 the pump, it's on, pump is free from debri and strainer clean, it sucks on my finger when I took the hose off. But I'm not sure how hard it's suppose too.
Old 05-15-2015, 03:44 PM   #4
Like Fonzie suggested, I had same problem. Was the anti-freeze input valve (my old camper did not have this feature).
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 05-15-2015, 03:45 PM   #5
Spits a lil water then nothing.
Old 05-15-2015, 03:49 PM   #6
fonzie's Avatar
As I said, make sure valve is turn so water pump pulls from fresh water tank and also the indicator lights are not always accurate...maybe put more water in tank just to make sure....
Fonzie
Old 05-15-2015, 04:08 PM   #7
VinceU's Avatar
Almost certain the pump is sucking air. The little vacuum on your finger is typical small pump with a small 3 gallon per minute rating. The valve on the suction strainer side serves the antifreeze/tank suction. Switch it from it's present position 90*, you should get an instant result.
Old 05-15-2015, 04:09 PM   #8
Drain plug pulled from hot water tank? If so, hot water shut offs are engaged so air isn't being sucked in? (Not positive this matters, kind of grasping at straws).
Lar & Ruth
Old 05-15-2015, 05:52 PM   #9
mzbrandi's Avatar
Just a thought that it is trying to fill the HW tank. That's 6 gals.
mzbrandi is offline   Reply With Quote
Old 05-15-2015, 07:29 PM   #10
Drain plug is in, hot water is 10 gallons, how long should I wait till it fills b4 I turn on the faucets? I have messed w the valve and nothin, going to drop the anitifreeze one in a gallon of water and see if it sucks
pump, water, water pump
