Old 09-18-2012, 06:35 AM   #31
In our Wolfpack
cenfl is offline   Reply With Quote
Old 09-18-2012, 08:18 AM   #32
b1b1das's Avatar
I need a bigger garage now...
ID:	19630   Click image for larger version
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
b1b1das is offline   Reply With Quote
Old 09-22-2012, 07:17 PM   #33
ebx
ebx's Avatar
What I Haul
2003 24' Work & Play
ebx is offline   Reply With Quote
Old 02-16-2013, 11:05 PM   #34
dsrace's Avatar
295 wolf pack and I haul a sand rail in mine
ID:	24400   Click image for larger version
ID:	24401   Click image for larger version
ID:	24402   Click image for larger version
dsrace is offline   Reply With Quote
Old 02-17-2013, 07:48 PM   #35
21Shockwave's Avatar
Originally Posted by bush View Post
Im new to the toy haulers and i have a 2011 800 rzr, was just wondering how everyone is securing their machines while in transport, i usually use car hauler straps on my flatdeck but none of the tie downs inside my new trailer dont really line up, im just wondering if a couple regular ratchets are enough!!
21Shockwave is offline   Reply With Quote
Old 02-17-2013, 10:43 PM   #36
dsrace's Avatar
my last toyhauler had 6 d rings for tie downs and i had a v6 rail at that time that weighed 1800 lbs. i didn't feel that was secure enough especially since those tie downs were cheapo made in china rings. i went and bought some e track from speedway motors and found the studs in the floor and lag bolted them down. never had any issues but with my new 295 fifth wheel wolf pack and new 1200 lb rail i just used 6 ratchet straps to all 6 d rings and it held up fine for the first trip. i will get more e track before too long for this one as well. i ran a lag bolt every other hole in the e track and 5/16" lags think you need to pre drill a 3/16" hole first. what does your 800 rzr weigh? 1000 lbs or 1200 lbs?
Old 02-18-2013, 01:46 AM   #37
Im hauling a side x side it's only 50" wide and dry weight of 950 lbs, i haven't used it yet so i was just curious
Old 02-18-2013, 06:59 AM   #38
Phat Phrog Phlunky
essness's Avatar
I have a built up golf cart that weighs in at just short of 1000 lbs. I use the d-rings and 4-1 inch rachet straps crossed, 2 in front and 2 in rear. By crossing them you keep the cart/load from walking to either side. I've got just shy of 7000 miles towing that way and no issues.
Now, if we could just remember to latch the fridge
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 02-18-2013, 03:33 PM   #39
Ok sounds good, cant wait to try it!! 😊
Old 02-18-2013, 04:53 PM   #40
dsrace's Avatar
remember to latch the fridge........that's funny cause i found my steak and other items scattered across my floor once too lol lol
at 950lbs or call it 1k lbs wet i think you'd be fine with the 6 rings and you can get better ones if you want to install them yourself, really easy if you have a roto zip tool.
