11-28-2017, 09:28 AM
Wheel chock question
I have a GreyWolf 22RR. Can someone post pics or suggestions on how you use your wheel chock.
11-28-2017, 09:37 AM
I only use the BAL X-Chocks, .... in spite of other post that will say you should not use only them, but use them in conjunction with the other wedge chocks, ... they stop the wheels from rolling, ...??... what more do you want?
11-28-2017, 09:39 AM
If you are talking about the basic wheel chocks I use 4. Normally between the tires. If I have to level with boards I make sure the chock has boards under it so same level as the tire. If on a steep hill I may put more chocks on the down side and less or none on the uphill side. I just kick them in with my shoe.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
11-28-2017, 09:56 AM
If you are using the Lynx Levelers (lego blocks) they make a wedge that interlocks with them that works quite well. Google/Amazon will get you to it. The camco version of the bal x chock works ok too. Just get the right size for your wheel spacing
2016 Flagstaff 27VRL Emerald
14K Equalizer
11-28-2017, 10:13 AM
I use both BAL X chocks
and heavier duty wedge wheel chocks.
It may be overkill, but a few years ago I had a trailer get away from me. I borrowed it from a friend at work, before we bought ours. I was setting up on a grade, and had his cheap wheel chocks behind the wheels. When I was unhooking it from the TV, the trailer rolled back as soon as the ball dropped out of the hitch. The cheap wheel chocks sunk into the ground and the trailer rolled right over them. It made it about 10 feet before the tongue jack stabbed into the ground and stopped it. Luckily there was no one behind me and no damage was done, but a scary situation none the less. Not something I ever plan to repeat.
021 Ram Rebel 1500
2017 Shamrock 233s
Waterloo, Iowa
11-28-2017, 10:34 AM
I use the X Chocks but in the back of my mind I always had this concern that a tire might lose air or go flat while we were not there OR someone might steal one or both allowing the TT to move or shift. So I have been known to use yellow wheel chocks as a security in addition to the X Chocks.
That's just my small paranoia though.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
11-28-2017, 10:41 AM
Made my own......
...and use both as needed.
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
11-28-2017, 11:07 AM
Well...the instructions say to not install them until you are done leveling so the question becomes, what are you using to keep the trailer from rolling during that time?
11-28-2017, 11:24 AM
Well, when I pull into a spot I level side to side before I unhitch. Once my Level Mate says it is level side to side on my Andersons I install the X chocks and place wheel chocks in place. The I unhitch and level front to back. Once that is done then I lower the stabilizers.
The whole process takes about 15 minutes in the daylight. Night ops may add 10 minutes.
Marty
2016 F250 SD 6.2L
While it's not evident from the first post here, the following text from another thread leads me to believe this OP is referring to an "inside the TH" chock:
"Quote: Originally Posted by slapshot12
I use a removable front wheel chock with 5 ratchets straps (1 thru front wheel, 2 off the front crash bars, and 2 off the rear crash bars) to floor mounted e-tracks. i installed the e-track so I can use it for my atv's and '15 HD Limited.
The mounts screw into the floor and the chock screws into them. When I don't use the chock, I just put the bolts in to plugs the holes and not to lose the bolts, and leave the chock in the cabinet.
Which wheel chock do you use? I have the grey wolf 22RR. "
11-28-2017, 11:28 AM
So...you install them before you are done leveling.
11-28-2017, 11:46 AM
Holy cow. You're right.
Marty
2016 F250 SD 6.2L
11-28-2017, 11:55 AM
Why interject logic now? The thread already has a life of it's own. LOL...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
11-28-2017, 12:19 PM
Right........ sorry it took me almost two hours to read and comment (and to find his post in the other thread). I'll try to do better!
11-28-2017, 12:42 PM
That is probably referring to side to side leveling, which of course is true, ... until your unit is level side to side, you are moving it to get it level(onto blocks, Andersen Leveler, ect.), so naturally you don't/can't install them until all movement is finished, and then .... X-Chocks, first and last, ... the first thing when parked(after side to side leveling is complete) and the last thing removed when leaving, ......
11-28-2017, 12:45 PM
If you look at their video on youtube, they say to level up and down before installing. Somewhere, I also saw some instructions they gave to use regular chocks as well.
Of course now it sounds like the OP wasn't talking about chocks on the outside of the trailer after all although he hasn't confirmed.
11-28-2017, 04:51 PM
I use this one in my current TH. When we get the new Momentum in a couple weeks, I'm going with a Biker Bar.
https://www.etrailer.com/Wheel-Chock...ax/TWSPWC.html
2015 Work n Play 30WLA
2017 Ford F-350 Lariat diesel, crew cab 4x4
11-28-2017, 05:14 PM
I use these. I don't secure the chock to the floor. Just drive the bike into the chock...or push it. I can get off the bike and the chock holds the bike upright, allowing me to attach the tie down straps by myself. Just as easy undoing the straps by myself to unload (loosen one strap a little then the other to keep it even until all tension is removed from the straps. When not in use I put them in the back of the truck while camping.
Works great on the BMW GS Adventure and the wife's Triumph Tiger 800. The KLR 650 has a skinny front tire which keeps the 'gripping' action from squeezing that tire (keeping the bike as stable) but still works by myself. If I place some rubber matting in the lower tire holder to fill the gaps, its just as secure.
https://titanlifts.com/chocks/titan-bulldog-wheel-chock
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
