Old 02-17-2018, 07:22 PM   #1
Which way is off for propane quick connect?
Just bought a 2018 sandstorm 283GSLR and it looked like the LP quick connect valve was in the middle instead of all the way one way or the other. Problem is itís not labeled on the valve so Iím not sure which way is on or off. I am assuming turning it clockwise shuts it off but I want to be sure because I believe this may be the cause to me running out of propane very quickly.
generallee01 is offline   Reply With Quote
Old 02-17-2018, 07:53 PM   #2
DieselDrax's Avatar
Do you have a picture? The only LP quick connect I know of looks like these...
https://www.etrailer.com/Accessories.../CAM59853.html
Which work like any standard ball valve, the opening is the same axis as the lever, so if the lever is perpendicular to the line then it's off and if it's parallel then it's on.
If you have a different kind of valve then a pic would be helpful.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 02-18-2018, 01:37 PM   #3
The valve on mine looks pretty close to the picture you posted. I would take a picture but my phones camera doesnít work so Iíll just go with perpendicular being off. I tried turning the valve on or off to listen to hear if any propane was hissing out but I didnít hear any so Iím curious if propane only comes out when something is connected to the fitting. Either way thanks for the advice I appreciate it!
Old 02-18-2018, 01:44 PM   #4
DieselDrax's Avatar
Correct, the quick connect fitting works similar to an air hose. The valve on the hose is to prevent gas from coming out as something is being connected and works as a backup in case the connector seals leak.
When connecting, make sure the valve is off (perpendicular) and then connect the hose. Then turn the valve on and make sure no leaks are heard/smelled.
When disconnecting, turn the valve on the line off first to let the device (BBQ, what have you) run out of propane, then turn the valves on the device off. This will ensure no propane is left in the device and none will come out when you disconnect it.
Enjoy!
2013 Shamrock 21SS
Old 02-18-2018, 01:50 PM   #5
cavie's Avatar
That is correct. There is a spring-loaded valve inside to stop you from doing just that. Usually, with the handle is 90 degrees to the valve is the off position.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-19-2018, 01:33 PM   #6
All gas valve work the same. If the handle is in line with the supply line it is on. If the handle is is cross way or 90 degrees to the supply it is off. Same applies to gas meters on a house.
WilliamG is offline   Reply With Quote
Old 02-19-2018, 01:34 PM   #7
On most of my quick connects, both on the TT and my extra hoses, you can't connect or disconnect with the valve on; the lever stops the collar from moving.
Springerdad is offline   Reply With Quote
Old 02-19-2018, 02:37 PM   #8
Mnemonic
The memory cue is:
Handle crosswise to flow=a gate across the flow
Handle inline with flow=gas is flowing in the line
Larry-NC is offline   Reply With Quote
Old 02-19-2018, 03:11 PM   #9
It may be hard to see but many handles are marked on & off.
Also as mentioned, the handle usually locks the collar when 'on.'
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 02-19-2018, 03:17 PM   #10
A properly functioning quick connect will not allow out-flow when disconnected even if the valve/lever is in the on (or partially on) position. If you are running out of propane quickly, you'll need to test the quick connect for leaks (soap bubbles) or find the source of another leak.
How quickly did you run out of propane and what appliances were you using?
Old 02-19-2018, 03:49 PM   #11
DieselDrax's Avatar
I don't know if the OP is new to RVs or not and I don't know where they're at, but it is winter. Propane furnaces will consume propane like it's candy, we had 2x30lb tanks on our 2010 31-foot TT and if we didn't use electric space heaters to keep the inside warm at night we would be out of propane in both tanks within 3-4 days.
If you're at an RV park with hook-ups then save money and hassle by using electric space heaters, save your propane for cooking.
2013 Shamrock 21SS
Old 02-19-2018, 09:49 PM   #12
Old Engineer
FleckDreher's Avatar
LPG = 91,000 BTU's per gallon
LPG = 4.3 Lbs per gallon
LPG = 21,163 BTU's per pound
So, a 20,000 BTU per hour furnace uses
0.95 pounds of LPG per hour of use
or 0.22 gallons per hour of use
FleckDreher is offline   Reply With Quote
Old 02-19-2018, 10:20 PM   #13
DieselDrax's Avatar
21,594BTU per pound and our 30k BTU furnace burned ~1.4LB/hr.
That means we'd get almost 43 hours of furnace run time with two full 30lb tanks.
The furnace ran around 50% of the time without space heaters so that would mean in roughly 86 hours we'd have gone through 60lb of propane; 3.5 days.
Needless to say, we bought a couple of space heaters when we filled up the tanks.
Curious to see what the OP reports back regarding temps and furnace use.
2013 Shamrock 21SS
Old 02-19-2018, 11:03 PM   #14
Denver, CO
garbonz's Avatar
Careful with electric heaters which don't circulate the heat like the furnace does and be aware of where your water pipe are etc. to make sure you don't save propane and bust water line and fittings. Happens a lot.
2017 Fuse 23T
Old 02-19-2018, 11:13 PM   #15
DouglasReid's Avatar
Precisely correct! The lever is a Fail Safe. It not only opens the ball valve but prevents you from connecting or disconnecting if the ball valve is open.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-20-2018, 09:09 AM   #16
Wolverine 1945's Avatar
X2 !!!
Wolverine 1945 is offline   Reply With Quote
propane
