Old 02-13-2011, 12:59 PM   #1
Wildwood Cable input?
I just bought a 2010 wildwood xlite 26bh. do they all have a cable input jack? Where is it located i cant seem to find it anywhere?
aaronh7 is offline   Reply With Quote
Old 02-13-2011, 01:04 PM   #2
Herk7769's Avatar
Look for a square flip up door with coax connectors in it. If there are two connectors one is for cable and the other is for Satellite.
The Satellite is a "home run" cable to a wall pad. The CABLE one goes to the back of the roof AMP wall plate. To enable the cable to work, you have to turn off the amp. (Green light out).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-13-2011, 01:09 PM   #3
the only thing i have on the side of the trailer is the power cable and the water connection so i am assuming my trailer is not prewired for cable hook up. I guess i should have looked a little more closely before i purchased it.
Old 02-13-2011, 01:12 PM   #4
Herk7769's Avatar
Do you have a roof antenna and a powered amp plate?
Old 02-13-2011, 01:15 PM   #5
yes
Old 02-13-2011, 01:28 PM   #6
Herk7769's Avatar
http://www.winegard.com/kbase/upload/2451486.pdf
The rear of the amp has three downward pointed coax connectors. The center one is the cable TV input. Make sure there is a cable there. If not you can add one. It is selected by pressing the little button and turning off the green light.
You can run a cable from that center connection to a convenient spot outside the camper and mount a waterproof box there. Winegard sells them or you can buy one at an RV store.
Old 02-13-2011, 01:34 PM   #7
thanks for your help i will definately check into that
Old 02-13-2011, 01:44 PM   #8
MtnGuy's Avatar
My cable hookup is just a coaxial connection covered by a rubber plug, with about a 2" round plastic frame around it.
Old 02-13-2011, 04:47 PM   #9
leencharlotte's Avatar
I have a 2011 Wildwood Heritage Glenn and my connections are on the back of th trailer rather than near my water/ elec hookups.
2011 Heritage Glenn 312QBUD
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 02-13-2011, 07:43 PM   #10
Cable inputs
I have a wildwood sport and it has cable input and a sat. Input at the rear of each side.They just have a rubber pull covers on each one.But mine is aluminum sided.
cessnajo is offline   Reply With Quote
wildwood
