Old 12-14-2014, 09:08 PM   #1
Winterizing
Leaving my 2014 Spartan in NM mountains for 2 weeks while I go home to Wa. Should I antifreeze the trailer or should I just drain all the lines while gone? Also, how do I drain the hot water heater? Leaving in 1 week so please help.....
polarbear is offline   Reply With Quote
Old 12-14-2014, 10:21 PM   #2
WFD
Winterize, winterize , winterize....it costs under $10 of antifreeze, doesn't take long, and you have peace of mind. What if a cold snap comes, and it could if your gone for 2 weeks, unless you really trust the weather people... If you drain the water, there will still be some in low lying spots, and what if they get a hard freeze and you are up in WA....nothing you can do and the headaches you will have after will have you cursing for a long time...if the forecast is decent you may consider blowing the lines out with pressurized air, and skipping the antifreeze, but that totally depends on whats in the forecast. If you do use pressurized air, be sure your compressor isn't putting out any more than about 40 psi., otherwise you may create further problems.
To drain the hot water tank just remove the anode rod...if it doesnt have the anode rod it will still have a plug in the same spot....first relieve any pressure in the tank with the pressure relief valve on the outside of the tank. If you decide to use antifreeze, remember to turn bypass valves on hot water heater so you don't fill it with 6 gal of antifreeze.
There are many Youtube videos showing all this, just do a search for Winterizing an RV. Winterizing really isn't difficult, and if you own an RV, you should get comfortable doing it, you learn a lot about your systems at the same time, that can help you trouble shoot in the future.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-14-2014, 11:13 PM   #3
SeaHarley's Avatar
I agree with WFD. At least drain the piping systems and the HW tank.
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline   Reply With Quote
Old 12-15-2014, 06:58 AM   #4
Dont forget to let the water out from the low point valves
Rcbstuff is offline   Reply With Quote
Old 03-07-2015, 07:00 PM   #5
WBilliot's Avatar
I agree.... Pound of prevention far out weighs pound of cure..... If we are not camping and cold snap is coming I grab antifreeze right then..... Takes about 10-15 minutes and save $$$$$ and the headaches of knowing while we are away, my TC (tuna can ) is taking care of ....
WBilliot is offline   Reply With Quote
Old 03-07-2015, 07:11 PM   #6
Ford Idaho's Avatar
I double dog dare ya to not winterize it......
Old 03-07-2015, 10:44 PM   #7
R3Jones's Avatar
Winterizing? Not sure what that is...I just make sure I turn off the lights here in Florida
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 03-08-2015, 11:10 AM   #8
WBilliot's Avatar
Wade grumbles at R3 Jones..... Wishing we lived in Florida where He could scuba for lobster once a year and enjoy the sun on the back at he fishes 😜😜😜😜
winter, winterize
