02-21-2018, 01:16 PM
#21
Originally Posted by vanderf
OK I found the break it is in the wall between the garage and the main cabin. My question is will it be under the wall in the garage or under the floor going up into the wall?? I don’t want to just start cutting holes
Thank you
An electrician with a signal tracer can help you
02-21-2018, 02:21 PM
#22
True but I bony know where it starts. Still trying to find a wording diagram. Thanks
02-21-2018, 02:28 PM
#23
Take measurements if you need to, in order to find out just where the wiring runs are. But, my wiring goes up into the walls from underneath the unit.
02-21-2018, 02:40 PM
#24
Thanks I sorta figured that’s its path but didn’t want to cut the barrier Do you know if there is space under the wall and the floor of the garage? The outside wire comes up between the tires the in toward the wall
Thanks. The more info I get the better it is
02-21-2018, 03:28 PM
#25
The walls sit on top of the floor.
There's a space between the coroplast and the floor. Most of the wiring, plumbing and heat ducts run through that space.
Gotta go campin!
02-22-2018, 07:01 AM
#26
You might want to start at the fuse box, just a heads up, we purchased a new 2018 Rockwood and the slide out was never wired from the factory. The dealership had to get in contact with the factory for the information and materials. Good luck.
Sent from my XT1650 using Forest River Forums mobile app
2022 Rockwood 8328BS
2019 Ford F150 Ecoboost Super Crew
02-22-2018, 07:07 AM
#27
In the fifth wheel garage is there space between the floor of the cabin and that of the garage?
02-22-2018, 08:14 AM
#28
Originally Posted by 270S
This hearsay thinking and accepting being bullied by the RV industry is why the problems continue. Do not take offense, but do not let them get away with this atrocious behavior. Insist on them doing it right - even if it is not the first time.
I did, will, and always insist on attempting to do it the right way. I have my TT wiring from FR factory, but it took 4 months, phone calls, emails, and .... Attached are only 2 of the dozen or so official "drawings" I had them send me. I had a 1 on 1 with my factory warranty rep. I can not say all of them are that good or nice - In fact most are _______. I'll let you fill in the blank.
I am sure yours are available!
Why don't you get with a member of the site team and post the schematics in the library?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
02-22-2018, 11:13 AM
#29
There is usually some space in there, but I'm not familiar enough your model to know how much. Some of them have enough space for a person to comfortably get into.
Gotta go campin!
02-22-2018, 02:31 PM
#30
Thanks I’m going to open it up in the morning and let you know if I find anything
03-04-2018, 08:21 AM
#31
Found the wires by opening up the interior wall got it all re-wires
Thank you all for your suggestions and knowledge it’s good to have others to bounce ideas off of
03-04-2018, 12:08 PM
#32
What problem did you find?
Andersen hitch
03-04-2018, 08:43 PM
#33
The wire pulled out of the wall between the garage and cabin Had to open it up and reconnect to the power supply. All good now
03-04-2018, 09:04 PM
#34
Thanks for returning to let us know. Glad you found it.
Andersen hitch
