Old 02-18-2018, 08:54 PM   #1
Wiring diagram
Iím looking for a diagram to help find the path of the 12v wire that goes into the slide out. I have no power to the lights. And no lights showing an open circuit in the Panel box
Any help would be greatly appreciated
thank you
Fred
vanderf is offline   Reply With Quote
Old 02-19-2018, 06:57 AM   #2
I've been told that there is no "official" wiring diagram to these trailers. Each installer has their own ideas about where the wiring for their particular component should run. You will likely have to trace the wiring hand over hand to find what you are looking for.
otrtrucker is offline   Reply With Quote
Old 02-19-2018, 07:05 AM   #3
cavie's Avatar
thank you
Fred
My trailer has a switch at the door to turn the lights on. Each light also has a switch. high/low/off. Give it a look.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-19-2018, 07:32 AM   #4
D W
D W's Avatar
X2. Run the slide out, crawl underneath and inspect the branch circuit harness that runs to the slide out.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 02-19-2018, 09:09 AM   #5
Thank you for your response
I did this and found a break but I still have no power and no fuse light on. I'm trying to find where its tied in. Any other ideas would be great thank you
Old 02-19-2018, 09:16 AM   #6
D W
D W's Avatar
Do you have 12v at the fuse?
2016 Salem 27RKSS
Old 02-19-2018, 09:22 AM   #7
electrical diagram
I had a similar problem where the slide had no power to it . I found the fuse for the slide was actually at a terminal block on the frame where all the wires connect from the battery.Trace your wires from the battery till you come to a terminal block, there you may find individual fuses hidden in the wiring. They are large amperage fuse's like 20 or 30 amp.
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
Happy Camper 2715 is offline   Reply With Quote
Old 02-19-2018, 09:24 AM   #8
Mr. Dan's Avatar
You're talking about power to slide motors. The OP is asking about power to 12v lights which would be much smaller fuses... not the same circuit as the slide motor.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 02-19-2018, 09:26 AM   #9
Mr. Dan's Avatar
This ^^^^.
Meter from fuse connection on one side to ground.
Meter from other side fuse connection to ground.
Do you have power on either side? Both sides? Some of us have learned NOT to trust the red "fuse out" lights.
Old 02-19-2018, 09:27 AM   #10
If the red light is not on is the circuits not powered? I'll check that out in the morning.
Old 02-19-2018, 09:28 AM   #11
No power to the lights
Old 02-19-2018, 09:36 AM   #12
Mr. Dan's Avatar
Yes... that's what I said --- to Happy Camper 2715. You are the OP.
Old 02-19-2018, 09:40 AM   #13
Mr. Dan's Avatar
I'm not sure what you said/asked there but we've see cases where the red light DIDN'T come on when the fuse was bad/blown... meaning the red light did not come on and warn that the fuse was blown. I'm not saying that's your case. I'm saying put a meter to it instead of assuming the fuse is good and the circuit is energized just because the red warning light is off. I hope this helps.
Old 02-19-2018, 09:49 AM   #14
Head Rambler
As Dan eluded to above, those blown fuse indicators aren't very reliable in the power distribution panels they put in these RV's. Test each fuse with a meter to make sure they're good. Even looking at them isn't a good way to tell.
Gotta go campin!
Old 02-19-2018, 10:12 AM   #15
Brother Les's Avatar
Did you have a bulb burn out and you installed a 'new one'? Check that bulb again for being correct.
Brother Les
Old 02-20-2018, 06:49 AM   #16
Thanks everyone for your help As I figured the wire was pulled and broke in the wall now I have to figure out the best was the open up and repair it. Never a dull moment but spring is near.
Thanks again
Old 02-20-2018, 07:19 AM   #17
This hearsay thinking and accepting being bullied by the RV industry is why the problems continue. Do not take offense, but do not let them get away with this atrocious behavior. Insist on them doing it right - even if it is not the first time.
I did, will, and always insist on attempting to do it the right way. I have my TT wiring from FR factory, but it took 4 months, phone calls, emails, and .... Attached are only 2 of the dozen or so official "drawings" I had them send me. I had a 1 on 1 with my factory warranty rep. I can not say all of them are that good or nice - In fact most are _______. I'll let you fill in the blank.
I am sure yours are available!
Name:	FR Interior Switch Panel.jpg
ID:	162924   Click image for larger version
Name:	FR JBox & A Frame.jpg
270S is offline   Reply With Quote
Old 02-20-2018, 09:13 AM   #18
Thank you I will start my calls today👍👍
Old 02-20-2018, 09:21 AM   #19
Herk7769's Avatar
Sure would like to see the rest of them!
Herk
HAM CALLSIGN - KC3FFW
Old 02-21-2018, 01:07 PM   #20
OK I found the break it is in the wall between the garage and the main cabin. My question is will it be under the wall in the garage or under the floor going up into the wall?? I donít want to just start cutting holes
Thank you
wiring, diagram
