Old 06-20-2017, 08:49 PM   #1
selandbe's Avatar
XLR Hyper Lite 29HFS under bed supports
I have a 2018 XLR Hyper Lite 29HFS and I would like to add the piston supports to the top of the under bed storage ... who has done that and what did you purchase to make this happen?
Thanks in advance for the help.
selandbe is offline   Reply With Quote
Old 06-21-2017, 11:32 AM   #2
Zoom's Avatar
I don't know if this helps but I changed the hinges toward the front and just used a stake to prop it up. Mine was hinged to the side and was almost impossible to use the space. I'm not sure what FR was thinking on the original design.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
Zoom is offline   Reply With Quote
Old 08-13-2017, 06:22 PM   #3
Chrism28's Avatar
I just got parts from amazon and used a 2x4 and screwed from the top I got a pretty heavy duty shock but if you were to put a thicker mattress on it would be fine
Chrism28 is offline   Reply With Quote
Old 08-19-2017, 10:52 PM   #4
I have a residential king size bed and the previous gas springs wouldn't hold up the additional weight. Bought some heavier duty springs on amazon and they work great. Suspa C16-17566 19.7" Gas Prop/Strut 150 lbs - Set of Two https://www.amazon.com/dp/B00BE5J542..._bCQd74JbZfUYV
trekdave42 is offline   Reply With Quote
Old 08-28-2017, 08:46 PM   #5
pjones1969's Avatar
I installed the STD kit from BedLiftkit.com, got it on Amazon
Very easy install, if your bed support does not have an actual hinge already you may want to add some, mine would jump off and end up on the other fixed piece, I was going to install a piano hinge but it seemed too flimsy so I installed basic gate type hinges on each side, works perfectly now
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
bed, lite, xlr
