Old 04-30-2016, 08:35 AM   #301
Originally Posted by gljurczyk View Post
If you got Trail Express "c" rated change them now to "d" rated I'll attach pictures of the rims they use and PSI of the rims. Also the rim should be stamped on the inside but the tire has to be removed to read it. may be this will help. If they are Alum alloy, or they could be I think they are called Sumac rims Rockwood and Flagstaff use the same rims.
They are C rated Constancy. No info available online for these except what someone at Lions head the distributor typed up for the warranty admin last week.
Thanks so much for the attachment. Mine look different I'll try to get a picture today.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 04-30-2016, 09:11 AM   #302
My wheels
Old 05-04-2016, 08:34 PM   #303
Now their compliance officer refuses to return my calls. My last FR.
Old 05-04-2016, 08:59 PM   #304
2012 Roo 19 - 3 yrs - no problems
2016 Mini Lite 2503S - only problem: Safety chains too short.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 05-04-2016, 10:42 PM   #305
I also found it quite childish that when I made a complaint about Flagstaff on their Facebook page, they deleted it and then blocked me from the page.
Old 05-05-2016, 08:23 AM   #306
raytwntrvlr's Avatar
Paul GA,
I have the same wheels and tires, as you, on my TT. With 6K miles and counting, I've not had a problem. I watch the air pressure and keep my cargo as light as possible plus keeping the speed down. So far I have only towed in cooler weather and my next trip (3K RT to Pacific NW) will be the same.
I would spring for larger wheels/tires if there was room but my axles are too close to fit 15 inchers.
Interesting that these same TTs now come with the 15 inch wheels.
To me there are no proven tire upgrades. All I have looked into, have their own share of failures. Even the vaunted Maxxis brand has a documented history of tire failures.
Speed, heat, loading and age must be managed to keep these "China Bombs" from detonating.
Happy Camping
2015 Flagstaff Super V 26VFKSS Emerald
2013 RAM 2500 CC 4X4 6.7 CTD
Sold... 2013 Shadow Cruiser 260BH
raytwntrvlr is offline   Reply With Quote
Old 05-07-2016, 08:52 PM   #307
2015 Silverback 31RK. Love it.
ba964 is offline   Reply With Quote
Old 05-10-2016, 02:05 PM   #308
Kenny kustom's Avatar
I've been trying to stay happy...
But it's hard.
My fifth went to the dealer in September for a list of repairs from the pdi. I bought the trailer new, a couple weeks before.
I had about a page of repairs to do.
I have been in contact over the winter, and they always said, waiting on parts.
I picked it up today. 3 things were completed, and that's just because no parts were needed for those repairs.
I start the dewinterizing.
Running water into sinks and such.
Go to the outdoor kitchen, run the taps for a bit, then I see water, dripping from the bottom of the trailer.
Start opening hatches and what do I see.
Name:	ImageUploadedByForest River Forums1462903397.608454.jpg
Bunk is flooded. I reattach.
Run the slide in.. It pops off.
Reattach. Run the slide out. It pops off. Yay.
I'm camping this weekend, then back to the dealer!
Check out the sweet cuts the factory made!! Click image for larger version
Name:	ImageUploadedByForest River Forums1462903498.403364.jpg
I think my 4 year old could cut better.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 05-10-2016, 02:53 PM   #309
PaulGA, what are the numbers that you think your tire ratings are not high enough? Take your GVWR - published tongue weight and divide by 4. If the tires are rated less than that then you have a legitimate claim for reimbursement, if not you don't.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-10-2016, 05:01 PM   #310
northstar1960's Avatar
your beating a dead horse . no question that they put the minimum allowable tire weight rating they can get away with . mine came with d rated tires not nearly enough for the weight of the TH loaded below max allowable cargo but then you deduct TG and they get by with no margin of safety . I agree with you in that it would cost no more money to just put on good tires rated above the max weight rating and have a bit of safety factored in . the excuse you'll here more then not is it's so people won't over load the units . this is a BS statement . good luck just bite the bullet and pick your wars .
northstar1960 is offline   Reply With Quote
forest river
