Old 06-05-2017, 08:26 PM   #1
Dometic refrigerator got hot!
I have a 2016 Rockwood Ultra light 33 footer that my wife and I are staying in as we build our new log house. My wife called me in to look at the freezer its hot and burnt she said! I went to see it and as I opened the freezer door I saw a long horizontal dis-colored yellow streak across the top edge on the inside and it was hot! Anyone else had this issue? We are using the electric mode not LP. We have only been in it for 3 months and we just came back from the lake last weekend and it wasn't like that then!It is plugged in to a RV type 30 amp plug in our new build with 200 amp service panel professionally installed.We turned it off and put our food in our house style refrigerator in our building.
Name:	Dometic Refrigerator.jpg
Ky Jim is offline   Reply With Quote
Old 06-05-2017, 09:07 PM   #2
Iwannacamp's Avatar
That's the door heater it looks like(assuming). Inside your home box sometimes there is a switch that says "economy" or " energy saver" or something similar to that. This is a heater designed to keep condensation down on the inside and out of the fridge.
2017 Puma 297RLSS
Old 06-05-2017, 09:43 PM   #3
Should it get so hot that it burned a small slit in the plastic? I've seen where several Dometic Refrigerators had cause fires,kind of scary since we stay in it every night !
Old 06-05-2017, 09:53 PM   #4
I looked for the switch you mentioned and didn't see one. I'm going to call Tom Stinnet Rv tomorrow.I bought this brand new and have a forever warranty on it. I hope they can do something about it.
Old 06-05-2017, 09:56 PM   #5
Below is a pic of the wiring for my fridge. You should have something similar for yours. In my pic, the door heater is labeled "K". It is wired in parallel with the inside light "G" and the doors light switch "H".
Name:	Fridge schematic 2.jpg
Never heard of a door heater getting that hot, but you can disable it. The attached shows you how to deenergize it at the light. If you don't care if you have the light or not, you can just pull the wire off of Pin J2. Note that your wiring MAY be somewhat different.
2011 Traverse LT, 3.6L, FWD
Old 06-05-2017, 11:12 PM   #6
Mine has two heaters one is like yours the other says LAC heater, but they are both on the #3 wire.
Old 06-05-2017, 11:18 PM   #7
I do have a light and it is LED several in a cluster. The light is off and I'm waiting for the heat element in the panel to cool down to see if it is off. Thank you very much and I will sleep better tonight for sure!
Old 06-06-2017, 02:43 PM   #8
Domestic refrigerator go tho!
We had the exact same thing happen in our 2016 Flagstaff last year on our second trip out with it. We sent pictures to our dealer and to Dometic. The unit was replaced at no cost to us.
ImGree is offline   Reply With Quote
Old 06-06-2017, 02:59 PM   #9
fonzie's Avatar
Here is another thread with same issue and resolution...
http://www.forestriverforums.com/for...92-125879.html
Fonzie
Old 06-06-2017, 05:21 PM   #10
Sounds like Dometic my have a problem! Very scary after seeing a new 5th wheel burn up at Nolin Lake 2 years ago. Thank God that the family wasn't there when it caught fire at 3 in the morning! They lost there car too because they left it parked right underneath the front the camper.
Old 06-06-2017, 05:23 PM   #11
Mine is a DMR -702.
Old 06-06-2017, 05:26 PM   #12
fonzie's Avatar
Originally Posted by Ky Jim View Post
Mine is a DMR -702.
The thread that I linked is for a DMR-702, title is wrong. Post #1 shows actual model number.....
Fonzie
Old 06-07-2017, 05:30 PM   #13
There are several of us FROGs that have gotten our DMR 702 refrigerators replaced for free by Dometic because of that very same heat strip issue. If you search for it you will find a thread concerning that. You need to contact your dealer about this asap. Don't settle for anything less than a new refrigerator. Mine was so bad it even burnt the door opposite the cabinet.
Semi retired now and enjoying it.
2013 F150 Super Cab 4x4, 3.5L ecoboost , 7700lb suspension package. 11,300 towing capacity and Max Tow package
2015 Flagstaff 8528IKWS Diamond
aquaholic3 is offline   Reply With Quote
Old 06-07-2017, 05:32 PM   #14
The link provided in an earlier post shows my fridge and another member's. One other member also posted his experience with the same problem.
Old 06-07-2017, 05:35 PM   #15
I called the dealer and I have a Forever Warranty that I purchased when We bought our camper. They said that all inside appliances are covered with full replacement as long as we bring it in every year to have it inspected, that even covers the roof. Thank God we purchased that warranty!
Old 06-07-2017, 05:38 PM   #16
Mine burnt the freezer door along the top also. Turned it yellow!
Old 06-07-2017, 05:39 PM   #17
Be advised that the "inspection" will most likely cost you money. Over the years, the yearly inspection cost will probably add up to more than you're going to save on this fridge. But that's how insurance works. Some folks make out and others don't.
Old 06-07-2017, 05:48 PM   #18
Considering that We have only had it a year and we pay $92 and some change a year. I'm pretty sure the frigerator cost more than that. I had a toy hauler by FR Work and Play and we never had any major problems for the 7 years we owned it. Only had a hot water controller go out and I replaced that myself. We raced dirt bikes and used it every weekend not even a leak in the roof and we used it to see the races my boys were in up there.
dometic, refrigerator
