05-13-2010, 08:25 PM
Get rid of the "P"-trap
I recently saw this mentioned in the FMCA magazine and found it quite interesting. The new Hepvo Valve replaces the standard P-trap under sinks and does not allow odors or gasses to enter the living area. Best of all because there is no water needed for it to work you don't have to worry about the P-trap evaporating dry. It was mentioned in the article that the valve makes more under sink room by eliminating the P-trap and can be mounted either vertically or horizontally and still work. It also does away with typical venting requirements.
For those of us that have bathroom sinks plumbed to the black water tank I can see this as a great product. Even if you just want to add more room under your sinks it might be worth looking into.
05-13-2010, 09:00 PM
Thanks for the info.
05-13-2010, 10:33 PM
interesting
Living in the Piney Woods of Texas.
05-13-2010, 10:39 PM
Must be the "type" of valve that is used with those "green" waterless urinals at some of the state and federal parks.
Neat idea.
05-13-2010, 11:44 PM
Location: Jacksonville Florida - Home of the Jaguars !!!!
I find that those waterless urinals tend to stink - literally. Nice to save water and all, but that system still needs improvement, IMO. It is sort of like not flushing the toilet, to rinse off what is on the porcelain bowl. It still smells. Randy
 '08 V-lite Flagstaff 30WRLS
'06 Ram 1500 QC hemi  Reese dual cam sway control,
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
05-14-2010, 12:27 AM
oh man the one on top of sandia peak in nm is HORRIBLY nasty smelly
i just about dropped dead.
05-14-2010, 01:03 AM
Neat idea.
Ummm, I don't think these valves are meant to be used on toilets, they are in lieu of a P-trap on sinks and showers.
05-14-2010, 07:29 AM
volunteer moderator
I wonder if it would actually pass code in the US?
05-14-2010, 08:02 AM
i believe that they are only approved for use on RV's in the U.S
05-14-2010, 11:31 AM
The FMCA article stated that several RV manufacturers are already using them. I believe it is probably the higher end units as I am sure they aren't as cheap as using a P-trap.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 412 |
| 65 members and 347 guests |
| 09grizzly1, 13Dano, amxpress, armye7, benjornada, bikendan, bird_dg, Born2.wander, brookside, Buffalohunter, campdohbrew, camper1953, caper, cbvp, cfsoistman, dashonthedash, dc31bhss, DDC, donn, Elanpottery, Emptypockets, F.R.O.G., f1100turbo, fonzie, frankm, gene17847, grhodes50, Hob, Homey55, huricane, JAJ73, jdudd, JFM-jr, KarenS144, ldmcmahan, LFugate, MikeDett, muzbomb, NorminN.B., Oakman, Old car, Papa Roo, ParrotHead, PrairieBoy, reinerka, Rest and Relax, rgmiller32, RubenZ, saskrick, Shasta1, smcneil, smithmdsmith, Steve7575, tentcamper1, tetsurvivor, TheSasks, thewren, thomeyer, tmmar, toybob, Triguy, vcarbona, wbillar, Wildwood Danny, zips2000 |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
