Old 05-01-2013, 10:37 PM   #41
Retired US Army CW4
Tom and Kat's Avatar
Originally Posted by Ron Chamber View Post
Question to all on unit slides?
How much can they take in wind or bad weather, before you take them in? Or would it make any difference, in or out for safety?
I spend a lot of time in the California deserts and the wind can really get nasty. I've been stuck in 50-60 mph winds with the slides out and never had any problems.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
Old 05-04-2013, 09:36 PM   #42
Noted one more design flaw in my unit and the one just arrived at the local dealer. The shower base is made such that water flowing down the wall travels out the corner and onto the floor. There is nothing in the shape to direct it toward the drain. I am putting some silicon sealant around the base and in that corner to direct it back into the base. Hope that solves it.
Ron Chamber is offline   Reply With Quote
Old 05-05-2013, 12:19 AM   #43
Phat Phrog Stunt Crew
awwall's Avatar
That's not the first time this issue has risen it's head. And the fix was exactly what you did!!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-07-2013, 10:16 AM   #44
Did some more research on my water leaks. Seems that during the PDI, the outside shower hose was turned on, then stopped the the shower head close valve. This valve does not completely close!! So any pressure was leaking from it to the bottom of the bin, then out the drain hole. Shut off the water at the knobs and water leak went away!!
Also pulled the sound control module to try and find where speaker set "C" went. They are cut and labeled right behind the unit, so just need to splice some more wire to them and run to where my speaker input will be.
Last small problem is the shower walls not sticking. Plan to put several small wood screws on both sides to hold it.
Old 05-07-2013, 02:01 PM   #45
Online_17's Avatar
Yeah, I read somewhere in the docs that speaker C was for future add ons. I may add bedroom speakers in the future or surround sound for the living room.
Happy to hear you got your water leak figured out.
My first cam is less than 2 weeks away...woohoo !
Online_17 is offline   Reply With Quote
Old 05-07-2013, 08:58 PM   #46
timarti's Avatar
Wonder what happened to the "doggie window" beside the passenger seat a la Ace. No longer shown or listed in options. I thought that was a great idea! Can't have been that costly. Should at least have been left as an option.
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
Old 05-07-2013, 09:33 PM   #47
Online_17's Avatar
Tell me about it?.. I didn't even realize until I got it home. I had to call the dealer to see if I got a defected coach....lol
Was totally expecting it. It was on their main brochure as a standard option.
Wonder what happened also....
Old 05-08-2013, 02:50 PM   #48
Anyone seen the latest version of FR3? The one I saw last week had the door access to under the dining benches removed and the plank under the seat changed to lift up for things in the benches. Also mine has a three part shower curtain bar so you can extend the curtain into the walkway, giving more elbow room. The new one has just a straight bar.
Old 05-10-2013, 01:56 PM   #49
Online_17's Avatar
Contacted Forest River today... The Doggie Window has been omitted and existing ones were from 1st release productions. No explanation....oh well
Old 05-11-2013, 03:19 PM   #50
New rv forest river fr3
We are looking at the FR3 and were wondering about cable hookup. It isn't mentioned in brochures. Is there a hookup for cable tv on the FR3?
Bosque Fire is offline   Reply With Quote
