Old 05-08-2017, 09:39 PM   #1
water heater takes long time to get water warm
after de winterizing my Oasis rl26.I made sure all lines were open and water heater was filled and all lines had no air.I started the water heater,after 10 min water was just luke warm. Is this normal or do I have an issue
PaPaMooseP is offline   Reply With Quote
Old 05-08-2017, 09:44 PM   #2
Platokidd's Avatar
give it some more time.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 05-08-2017, 09:49 PM   #3
thank you
Old 05-08-2017, 09:58 PM   #4
SeaDog's Avatar
If you are plugged in and have both propane and electric you can heat things up a little faster by running both at the same time. thats what I do when folks are showering
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-08-2017, 10:12 PM   #5
thank you I ll keep that in mind
Old 05-08-2017, 10:28 PM   #6
Normal. A 1500 watt elect heating element sily takes some time to make hot water. Even on gas it can take 30 minues to get up to temp.
donniedu is offline   Reply With Quote
Old 05-08-2017, 10:59 PM   #7
thank you
Old 05-09-2017, 01:27 PM   #8
DustyRoads's Avatar
Also make sure bypass valve is closed. Otherwise you will mix cold with the hot.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
DustyRoads is offline   Reply With Quote
Old 05-09-2017, 01:35 PM   #9
TGR
TGR's Avatar
If a little more time didn't resolve your hot water temperature problem, you may not have closed the bypass valve that diverts water around the water heater during winterization. This will cause cold water to mix with the hot water and affect the temperature and apparent capacity of the water heater.
Many designs use 3 valves to bypass the water heater during winterization. In the spring, the valves are placed in the normal use position, i.e., the two valves going to and from the water heater in the open position and the bypass valve in the closed position. Perhaps this is the problem.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 05-09-2017, 03:12 PM   #10
Thank you folks.
Old 05-09-2017, 03:29 PM   #11
On electric only, my water heater takes a good 20-25 minutes to get up to temperature.
On propane only, it takes about 15 minutes and both on at the same time takes about 12 minutes. I've timed it.
It's also somewhat dependent on the ambient temperature of the water coming into the tank as well.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-09-2017, 05:26 PM   #12
Good to know folks thanks for all the info
Old 05-09-2017, 06:59 PM   #13
Platokidd's Avatar
follow up, do you have hot water yet
Seasonal
Old 05-10-2017, 12:14 AM   #14
Yay got hot water took about 35 minutes.Thank you for the advise.
Old 05-10-2017, 09:36 AM   #15
DustyRoads's Avatar
Was is just that it took longer than expected or was bypass valve open.
heater, water, water heater
