Old 05-04-2016, 06:09 PM   #1
What a Dealer Finds in a PDI on New Unit
Name:	Vent Covered.jpg
I work at a dealership that sells Forest River trailers and I also own a Cedar Creek trailer. I have watched the forum and read the difficulties new owners have with new units and do feel your pain. I spend anywhere from four hours to two days doing PDIs on new units and fixing things from the factory before they are put on the lot. They also get another PDI when sold which if was done right the first time I did it should be quicker. I could not pass on showing what I found today on a new travel trailer. On the roof were two vent pipes that had left the factory with no caps installed, just two holes in the roofing and the roof itself, and lots of water damage inside of course as unit had sat in the lot for a month. We will now have to take out one wall and a ceiling to fix. One other vent, and all other openings in the roof including a tv antenna right beside the vents pictured which were about 8 inches apart, were sealed properly. One picture is one of the vents I did attach and seal properly. Must have been lunch time when it came to adding caps and sealing the last two vents at the factory. When you purchase a trailer, go over every inch of it with a fine tooth comb and if you have a good dealer they should assist you in the inspection as they do get paid to fix any warranty items and should know what to look for.
John and Julie Parish
Lansdowne, Ontario, Canada
2015 Ford F250 Diesel
2009 Cedar Creek 34RLSA
Retired but still working sometimes to pay for toys
jdp105 is offline   Reply With Quote
Old 05-04-2016, 08:15 PM   #2
I go RV'ing not Camping
jgourlie's Avatar
Thanks for posting this. I think it's so important on the dealer that you buy from, a dealer that cares goes a long way
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-05-2016, 06:35 AM   #3
Thanks for posting, wish all dealers were this thorough even tho they should not really have to be if done right from the start.
dblr is offline   Reply With Quote
Old 05-05-2016, 06:58 AM   #4
I was looking at local dealers but ended up going a bit farther to a larger dealership.
I was not disappointed. They were great. For sales, the service and PDI I was impressed. They had a small RV park adjacent to their lot so I told them I would set up and spend a night there making sure all things worked before accepting the unit. That went great. DW baked a cake in the oven, we operated everything, lights,sinks,slideouts, the works. Any help I needed was right there and friendly. We found a few things that need repair and some parts were/are on order, so we left the unit there for later pick-up.
Good to hear from a dealer service person on here. Maybe they need their own page. Their side of the equation might make for some interesting reading.
RMc
Wheels Down is offline   Reply With Quote
Old 05-05-2016, 07:08 AM   #5
Steeljag's Avatar
JDP - Is there a reason you are aware of the dealership does not send these type units back? Especially with roof issues and water damage?
Thanks for posting!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-05-2016, 11:29 AM   #6
Dazed & Confused
M&K Hoffman's Avatar
Just out of curiosity do units damaged like this get sold a brand new units or rebuilt units? Is the customer advised of what has happened to the unit? Or is that something that laws might vary state to state? BTW I know what the ethical answer should be.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 05-05-2016, 11:37 AM   #7
MT Biker's Avatar
The dealer we purchased our Micro Lite 23FB from paints the frames on every trailer they receive before selling them.
They claim that I would never want to see what the frames looks like from the factory!
https://www.facebook.com/westshorerailway/
2019 Ford F-250 Super Cab 6.2L Lariat
2016 ML23FB
MT Biker is offline   Reply With Quote
Old 05-05-2016, 11:58 AM   #8
Currently in a love hate relationship with our dealer...
The dealer we have has taken good care of us this far, but I fear they will get sick of hearing from me shortly.
When we picked out the trailer ( 2011 Shamrock ) we knew it was used, so some busted molding, little dirt here and there, bent curtain bar with stripped screw, and some blemishes on the exterior ( small dent in the corner) were to be expected.
Dealer touted about the huge inspection process they go through even on used units at this visit.
9 days later we drive an hour to go pick up the new to us trailer. As the tech is showing us around he opens the fridge vent on the outside... leaves and dirt fall out... same for the hot water vent. Shows us the light on the front to assist with hitching at night - burned out, opens bunk, protective pad is hanging off the latch from a rubber strand. Go inside, stove light doesn't work, sealant around the AC is hanging down, Plastic redirects for the exterior gutters are sitting in the sink, Curtain bar is still bent- screw missing
They fixed these issues while we waited - but if they inspected it didn't take much to find these issues.
Get the TT home and set up in the driveway - Scissor jack is mangled, rod is so crooked it hits the camper floor ( plate bent about 45 Degrees on camper) Rain that night bunk ends all leak like a sieve, tested with hose sure enough, they all leak. Bring it back up the hour drive to the dealer, they install all new seals and bend the scissor jack plate down. Works but that jack is wobbly
Back home, prepping 2 days before our first trip. De-winterize the system. Bypass was not on the hot water heater, buildup of pink crystalline material is all the way out to the last thread on the heater anode core. Rest of De-winterization goes well, no leaks, pink stuff all gone. Open water well and sewage drain expecting pretty much just water/coolant.....NOPE! brown stuff!!! They didn't even flush the tanks out...
Hopefully we are past the issues we have found, and we can just enjoy the camper now
Chris
Stygshore is offline   Reply With Quote
Old 05-05-2016, 01:14 PM   #9
Our dealer conducts post sale seminars for their customers. At the last one I attended the technician told us they need to re-do or correct some of the roof caulking on most of the RV's that arrive from the factory.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018
CNYCamper is online now   Reply With Quote
Old 05-05-2016, 01:47 PM   #10
PDI
Originally Posted by jdp105 View Post
Attachment 106900
Attachment 106901
I bought a Sunseeker 2500TS from a Forest River dealer in Burlington Ontario, and it seems to me they did not know what PDI meant. My unit clearly did not get much of an inspection. I base this comment on the things I found wrong with it after I got home.
papakilo is offline   Reply With Quote
dealer, pdi
