Old 09-30-2018, 05:21 PM   #1
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
Added electrical box on its own circuit
We’ve frequently tripped a breaker especially in colder wedther when we’ll have a heater running. We’ll forget to turn off the heater and will run a coffee pot or toaster or some other electrical demanding appliance.
As I looked at the converter / electrical breaker / 12 volt fuse panel which is under my refrigerator I thought there was enough room to add an additional outlet. I wanted to run the outlet on its own circuit breaker. I pulled out the converter and found room in the panel next to the converter. I used a retrofit electrical box, cut the hole in the paneling and mounted the box. Ran wire into the converter, and installed an additional 15 amp breaker. Made all the connections and new I have an electrical plug on its own circuit. No more tripping breakers.
ID:	187885   Click image for larger version
ID:	187886   Click image for larger version
eprovenzano is offline   Reply With Quote
Old 09-30-2018, 06:35 PM   #2
It is always good to have high amp items on their own circuit. You may find that if you get more high amp circuits running you will get your main breaker to trip. You will then have to decide what items you want to run anyway.
BarabooBob is offline   Reply With Quote
Old 09-30-2018, 06:59 PM   #3
Lacey's Spring, AL
formerFR's Avatar
yep, most of the time the factories don't give us enough SEPARATE circuits, for times like these... otherwise it makes you have to 'share' the circuit with another 'larger' appliance or device, which aggravates the owner when they want to do both at the same time : /
travel, park, enjoy!
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 09-30-2018, 07:10 PM   #4
I agree, but I feel better splitting the electrical load onto seperate circuits.
Old 10-01-2018, 01:05 PM   #5
Did the same for the same reason on a little PUP years ago. Our furnace would startle us awake each time it fired, so when we had shore power, we'd use a little 1500 watt ceramic heater to heat the PUP instead of the furnace. Worked great. Use a high quality GFCI outlet just in case.
P.S. But don't rely on this arrangement and overload the circuit if you've stepped down from 30 amps to a 15 amp connection if plugged in via a step-down adapter. You'll blow the breakers from your supply source...for example, your home. Then you're back to choosing one or the other.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 10-01-2018, 01:47 PM   #6
Additional electrical box
Two years ago I added a totally separate outlet that bypasses everything in my 2006 Surveyor, including the converter.
I installed an outlet on the front panel of the sink cabinet so that I could hide the wire. I ran the wire down through the floor and installed an exterior outlet box under the floor (about 6 inches in from the exterior side of the trailer.)
I then retrofitted a second Male plug onto a 50 foot # 12 extension cord so that I could plug one end into the campsite pedestal 110 outlet and the other end into my new exterior outlet.
I have run a 1200 watt heater many times with this setup with no problems.
Barry1 is offline   Reply With Quote
Old 10-01-2018, 06:12 PM   #7
Did the same for the MH so we can run two space heaters at opposite ends to balance the heat. Can run both heaters on low to med down to about 40 degrees outside.
markb422 is offline   Reply With Quote
Old 10-01-2018, 06:41 PM   #8
Actually in many cases, the factory has no choice based on the electrical code. If you have a residential reefer, an electric hot water heater and an air conditioner (i.e. more than 2 thermostatically controlled loads) they cannot have more than 5 breakers on a 30 amp unit. It is just the way it is!
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-01-2018, 08:26 PM   #9
Barry1, Do I understand you have TWO (2) Male ends on an extension cord? That's totally unacceptable. I hope I'm wrong in my understanding of your post. Your going to get someone seriously hurt someday if that's true.
weatherguru1 is offline   Reply With Quote
Old 10-01-2018, 08:34 PM   #10
cavie's Avatar
NEVER use an extension cord with two male ends. You will get somebody killed!!! use a proper WP male plug on the trailer.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
electric, electrical
