Old 03-25-2011, 06:59 AM   #11
miatared's Avatar
I too am curious, as we have not had any issues and had some serious cold nights and high humidity.
Only the two of us. The better half sleeps on one end, and I on the other one, so maybe lots of body heat is a source.
We do put the heater on at night - low setting but still on.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 03-28-2011, 12:31 AM   #12
cmcct's Avatar
Yup, I do, Roo 21. Oh, and vinyl bottom matresses.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 03-28-2011, 06:53 AM   #13
yvesm's Avatar
When we had our Shamrock I also used the ridgid foam insulation under the mattress. I used hook and loop to keep it in place and the insulation reduced the condensation a lot. We did always sleep with the bunk end zippers opened a bit to let the moisture escape while we were sleeping, this kept the moisture from condensating on the tent end and dripping on us in cold weather, especially if it was a damp rainny night.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 04-05-2011, 08:38 PM   #14
baldy's Avatar
What about the foundation wrap that is dimpled like delta ms foundation wrap. it would allow the air to flow in between thus eliminating the temperature variance.
baldy is offline   Reply With Quote
Old 04-06-2011, 08:16 PM   #15
Our first night was a cold rainy night. We had everything buttoned up tight. The condensation was OUT OF CONTROL. Not sure about under the matress, as we did not look, but inside the bunk ends on the canvas, the windows, etc. it was WET inside. After that first night, we keep the fantastic fan on the entire time. We bought a cover for the vent on the roof, so it can be open in the rain. The fan goes on as soon as we hook up to power and stays in until we unplug. Once we started to do this, we have had ZERO condensation in the camper, regardless of outside temp. 80+ degrees or lows around 40 degrees. This may help you all as well.
southpaw821 is offline   Reply With Quote
Old 04-10-2011, 08:02 PM   #16
hockeytownmom's Avatar
I've got to try this.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 04-11-2011, 05:20 AM   #17
Triguy's Avatar
What cover is everyone using - Maxx air II?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-11-2011, 07:46 AM   #18
miatared's Avatar
My cover is the Fan/Mate 850 by Maxxair in white - designed for the Fan-Tastic fan.
I crack open a corner of the canvas at both ends and the fan is on all the time too - maybe that's why but I've not yet had any condensation issues -and we did camp in cold and rainy weather last summer.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
Old 04-11-2011, 10:29 AM   #19
bikendan's Avatar
just an update on the mod.
recently went camping and had the foam insulation with the silver side facing up, towards our body heat.
mattress was still damp underneath. we did run the heated part of the mattress, all night.
next time, will try with the silver side down, towards the outside cold temps.
Old 04-11-2011, 10:34 AM   #20
Triguy's Avatar
Bummer. Thanks for the update.
Scott
2012 Shamrock 233S
