Old 03-03-2017, 10:53 AM   #41
Picking up a new to us 2013 233S tomorrow but it's missing the grill. I have a Weber Q that I'd rather use anyways. I took the rail mount stove out of the popup to use outside. I would rather have a stovetop outside than only inside. Too bad I can't use the quick disconnect since the rail mount stove is a high pressure stove.
Chunk6649 is offline   Reply With Quote
Old 03-03-2017, 11:42 AM   #42
The RVQ rail bracket you slide the grill on the wall will also sit on a table. The grill itself has a "T" bracket that allows the bracket to slide in from the back or bottom. Just set the bracket on a table and fold the steel rods up and slide the rods into the side of the grill.
Old 03-03-2017, 12:00 PM   #43
satdog01's Avatar
Use the grill that is bumper mount on our Flagstaff quite often. The problem I have is the temperature stays above 400 degrees all the time. Called the supplier to FR and they are sending me a new flame adjustment, apparently this is an issue. Will know when I install the new part. Like the concept of the grill as it stores nicely in outside kitchen and had a convinent quick connect by the rear bumper.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
satdog01 is offline   Reply With Quote
Old 03-03-2017, 12:10 PM   #44
beechjet16mf's Avatar
Grill
We use our outside grill all the time. It and the little table came with the trailer from Cheyenne Camping Center, and it has worked very well. My only complaint is it is a little work to clean it.
beechjet16mf is offline   Reply With Quote
Old 03-17-2017, 01:16 PM   #45
deartruc's Avatar
We also use the bumper mount grill. Only complaint I have is the springy ness of it. Saw a new mounting system at the camping show. Haven't been able to find it online. Doesn't use the arm mount that comes with the grill. This bumper mount has two vertical bars (that use the vertical brackets like when used for free standing)
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 03-18-2017, 07:34 AM   #46
bareftn's Avatar
Originally Posted by scbee View Post
Anyone use or have used in the past either the propane grill that comes with the trailer, or other unit mounted ion the rail on the outside of the trailer?
If so, any issues with having heat that close to the trailer? Any melting, or other damage?
We always and only use our GF grill
bareftn is offline   Reply With Quote
Old 03-18-2017, 08:45 AM   #47
Wolverine 1945's Avatar
We had a TT for about 8 years that came with Grill,,, we never used it because I did not want the heat & smoke under the awning,,, and did not want to put the dirty Grill back under the bed for storage !!! We only used the trailer up north on our property,,, where we keep a little Weber Smokey Joe charcoal grill !!! Now we carry a cheap little Gas Grill in our Sunseeker,,, Will probably buy a small Stainless Steel Table Top Grill from Sam.s when it dies !!! Only 2 of us so don't need anything very big,,, but am not into carrying charcoal & starter !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-20-2017, 05:31 PM   #48
B and B's Avatar
Used the trailer mount RVQ on both Rockwood TT and 5er. Works and used it for 6 years. Moving to Heartland BigHorn and bought a Costco NextGrill with a 20 lb tank.
B and B
Old 03-24-2017, 03:30 PM   #49
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
I don;t have the grill connection for the side of the camper... I am in the process of converting my portable grill to a low pressure unit so I can utilize the quick disconnect low pressure gas on the HTT. I've always set the grill up away from the camper.
eprovenzano is offline   Reply With Quote
Old 03-25-2017, 08:12 AM   #50
Sams & Home Depot have grills just like the Nsexgrill for $99,,, Sams also has a Smokey Hollow for $75 !!! Stainless 1 Burner !!!
Old 04-23-2017, 06:40 PM   #51
Summer2Go
Summer2Go's Avatar
Have always used the grill that came with the pop up as well as my Roo. I love that it doesn't require a separate table. I could see the difference in quality from my 2003 camper to the 2016 one. Still good, and yes, hard to clean.
Summer2Go is offline   Reply With Quote
Old 05-01-2017, 07:54 AM   #52
We use our grill attached to the camper with the awning out and never have any issues. It is not my first choice for cooking as we will opt for carcoal on a camping trip every time, but for small amounts and quick grilling, it is perfect except for clean up as everyone has mentioned.
2015 ROO 233S
2013 F150 Eco Boost
1Roo4Ladds is offline   Reply With Quote
Old 05-01-2017, 08:48 AM   #53
Our 2006 Flagstaff came with a Gas Grill,,, I never used it because I did not want to store a dirty grill under our bed,,, so I always used a Little Smoky Joe charcoal grill that we left on our property up North !!! Great size grill for 2 people !!! Now we have a Sunseeker we use a small gas grill,,, but am looking @ the Tabletop Stainless Grill that Sam's sells !!!
Old 05-13-2017, 01:24 PM   #54
Summer2Go
Summer2Go's Avatar
I love using the grill. There is no damage to my awning. I get more stains on the underside of the awning from it being rolled up all winter. Moisture gets inside and stains it, I have to wipe it down with a cleaner every spring.
mount
