Old 03-03-2017, 09:53 AM   #41
Picking up a new to us 2013 233S tomorrow but it's missing the grill. I have a Weber Q that I'd rather use anyways. I took the rail mount stove out of the popup to use outside. I would rather have a stovetop outside than only inside. Too bad I can't use the quick disconnect since the rail mount stove is a high pressure stove.
Chunk6649 is offline   Reply With Quote
Old 03-03-2017, 10:42 AM   #42
The RVQ rail bracket you slide the grill on the wall will also sit on a table. The grill itself has a "T" bracket that allows the bracket to slide in from the back or bottom. Just set the bracket on a table and fold the steel rods up and slide the rods into the side of the grill.
Old 03-03-2017, 11:00 AM   #43
satdog01's Avatar
Use the grill that is bumper mount on our Flagstaff quite often. The problem I have is the temperature stays above 400 degrees all the time. Called the supplier to FR and they are sending me a new flame adjustment, apparently this is an issue. Will know when I install the new part. Like the concept of the grill as it stores nicely in outside kitchen and had a convinent quick connect by the rear bumper.
Marriot2 on Wheels 2017 Flagstaff Classic 832 OKBS
2013 GMC Denali 6.6L 2500 HD DMAX w\Alison Trans
Pepper Pomeranian rescue 121 days as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
... 2014 = 39, 2015 = 52, 2016 = 77, 2017 = 11
Retired :
satdog01 is offline   Reply With Quote
Old 03-03-2017, 11:10 AM   #44
beechjet16mf's Avatar
Grill
We use our outside grill all the time. It and the little table came with the trailer from Cheyenne Camping Center, and it has worked very well. My only complaint is it is a little work to clean it.
beechjet16mf is offline   Reply With Quote
Old 03-17-2017, 01:16 PM   #45
deartruc's Avatar
We also use the bumper mount grill. Only complaint I have is the springy ness of it. Saw a new mounting system at the camping show. Haven't been able to find it online. Doesn't use the arm mount that comes with the grill. This bumper mount has two vertical bars (that use the vertical brackets like when used for free standing)
2008 Dodge Durango
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 03-18-2017, 07:34 AM   #46
bareftn's Avatar
Originally Posted by scbee View Post
Anyone use or have used in the past either the propane grill that comes with the trailer, or other unit mounted ion the rail on the outside of the trailer?
If so, any issues with having heat that close to the trailer? Any melting, or other damage?
We always and only use our GF grill
bareftn is offline   Reply With Quote
Old 03-18-2017, 08:45 AM   #47
Wolverine 1945's Avatar
We had a TT for about 8 years that came with Grill,,, we never used it because I did not want the heat & smoke under the awning,,, and did not want to put the dirty Grill back under the bed for storage !!! We only used the trailer up north on our property,,, where we keep a little Weber Smokey Joe charcoal grill !!! Now we carry a cheap little Gas Grill in our Sunseeker,,, Will probably buy a small Stainless Steel Table Top Grill from Sam.s when it dies !!! Only 2 of us so don't need anything very big,,, but am not into carrying charcoal & starter !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-20-2017, 05:31 PM   #48
B and B's Avatar
Used the trailer mount RVQ on both Rockwood TT and 5er. Works and used it for 6 years. Moving to Heartland BigHorn and bought a Costco NextGrill with a 20 lb tank.
B and B
2017 Heartland Bighorn 3575 Elite
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
mount
