Old 12-29-2014, 05:54 PM   #11
Best way to fix a flat is to get rid of it and replace it with a new tire of the same brand ,LR.and tread design. The inside patch is the best way to patch it,but I wont run a patched tire any further than I have to to get a replacement. A patch job would be OK for a spare,butthat would be it.
trbomax is offline   Reply With Quote
Old 01-02-2015, 09:05 PM   #12
cogito ergo moo
Cowracer's Avatar
do NOT NOT NOT jack a trailer axle from the middle. get your jack under the leaf spring perch before jacking. More than one axle has been bent and ruined by sloppy jacking procedures.
Its always best to read the manual and crawl under and look things over in your driveway at least once, instead of waiting till you are on the side of the highway to figure out where to put the jack.
FROG Member MO-0008-571 Since 2012
2016 Rockwood Signature Ultralite 8329ss (coming soon)
Nights camped 2016 -9
Nights Reserved 077121212125 ..........My Project Blog:
Cowracer is offline   Reply With Quote
Old 01-02-2015, 09:13 PM   #13
asquared's Avatar
Originally Posted by Taranwanderer View Post
I would say the easiest way to change a tire on a dual axle trailer (which it looks like the Roo is) would be to get one of these and carry it along all the time:
Rhino Ramps, Set of 2 - Hopkins 11909MIE - Chocks & Levelers - Camping World
You loosen the lug nuts on the flat, then pull forward or back up onto the ramp with the other axle's tire, leaving the flat dangling, pull it off, put spare on, tighten lug nuts, move trailer down off the ramp, and retighten. No jacking required.
These do not work for all dual axle trailers. My old tt had the wide stance. I drove the front tire on and the rear tire stayed on the ground. Had to Jack it up instead.
<a href= target=_blank></a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 01-02-2015, 09:24 PM   #14
deartruc's Avatar
Originally Posted by WFD View Post
Lesson learned....every trailer needs to have a hydraulic bottle jack in it's storage for this exact reason.
2008 Dodge Durango
2015 Roo 23 ikss
deartruc is online now   Reply With Quote
