12-29-2014, 11:00 AM
Best Way to Fix a Flat?
What's the best way to fix a flat tire on a Rockwood Roo 233s?
12-29-2014, 11:35 AM
Take tire off and take it to your favorite tire repair place.
12-29-2014, 11:47 AM
Does the trailer tongue need to be disengaged from the hitch when using the jack to remove the tire? I'm on an incline and would rather not !!
12-29-2014, 11:49 AM
No it doesnt need to be un-hitched
12-29-2014, 12:49 PM
If needed, would you just use your truck's tire jack?
12-29-2014, 01:08 PM
I would yes. If it's short enough to fit.
12-29-2014, 04:44 PM
Lesson learned....every trailer needs to have a hydraulic bottle jack in it's storage for this exact reason.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
12-29-2014, 04:59 PM
Don't let them 'plug' it, insist on a patch from the insdie
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
12-29-2014, 05:32 PM
thanks all. the tire jack worked.
I'll insist on a patch from inside too.
Mike.
12-29-2014, 06:23 PM
I would say the easiest way to change a tire on a dual axle trailer (which it looks like the Roo is) would be to get one of these and carry it along all the time:
Rhino Ramps, Set of 2 - Hopkins 11909MIE - Chocks & Levelers - Camping World
You loosen the lug nuts on the flat, then pull forward or back up onto the ramp with the other axle's tire, leaving the flat dangling, pull it off, put spare on, tighten lug nuts, move trailer down off the ramp, and retighten. No jacking required.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
12-29-2014, 06:54 PM
Best way to fix a flat is to get rid of it and replace it with a new tire of the same brand ,LR.and tread design. The inside patch is the best way to patch it,but I wont run a patched tire any further than I have to to get a replacement. A patch job would be OK for a spare,butthat would be it.
01-02-2015, 10:05 PM
Broken Toe
do NOT NOT NOT jack a trailer axle from the middle. get your jack under the leaf spring perch before jacking. More than one axle has been bent and ruined by sloppy jacking procedures.
Its always best to read the manual and crawl under and look things over in your driveway at least once, instead of waiting till you are on the side of the highway to figure out where to put the jack.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
01-02-2015, 10:13 PM
These do not work for all dual axle trailers. My old tt had the wide stance. I drove the front tire on and the rear tire stayed on the ground. Had to Jack it up instead.
2014 Sabre 34REQS-6
01-02-2015, 10:24 PM
x2
2017 GMC Yukon
2018 Roo 23 ikss
