04-20-2015, 11:34 AM
Brand new hybrid bunk leak.
Our 2015 Shamrock 21DK has been exposed to alot of rain this past week...picked it up monday in the rain, and its never dried out enough to close it back up. I had read someplace that the seams need to get wet to swell and seal, so we have kept a close eye...overnight monday the rear bunk had some water get in, appears to have gotten in under or around the bottom of the tent where it attaches to the bed. not alot but in several places. The next rain it was dry after, but wet again after the 3rd day. I can see clear silicon on the corners but not on the rest of the seam attachment. Anyone else seen or heard of this?
I've talked to the dealer and a tech is supposed to call me back about it.
04-20-2015, 01:19 PM
Take The Road Less Travld
We ran into this the first week we got our Roo. It was open with several days of rain before it had a chance to dry out. Just like you, it had one day of drying out, then back to rain where yes, I had more leaks. there was not enough time to properly dry in the sun before the next days rain hit. I removed the beds from the bunk ends to keep them dry and prayed while towling off the bunk ends several times a day. Be assured, that once you get some sunlight and more then 24 hours of time without rain, you will be fine. I have not had an issue since.
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
04-22-2015, 10:15 AM
Yetavon, a couple weeks after I first got my 2015 Shamrock 21DK, I'd go to open up the bunk ends and notice just a small amount of water laying on the bottom lip in same spot you mention. After searching on this forum I found the very easy PVC mod to add to the top of the bunk doors. Since adding these I see no more evidence of water in that bottom lip when opening up the bunk ends. To hold the PVC in place while traveling I simply drilled out 2 small holes on each end and just ran a clear tie wrap thru it, secured to the bunk latch. Works great. Pain in the ass to have to add something to a brand new trailer to keep it from leaking but thus is the nature of a hybrid I guess. It's an investment so better to be safe than sorry and the mod is cheap n easy fix.
Skidog
2008 Dodge Ram 1500 Big Horn
2015 Flagstaff Shamrock 21DK -sold
2016 Grey Wolf 29BH
04-22-2015, 03:45 PM
Thanks all, But Skidog this is with the bunks open that I got the leak, but have seen that PVC mod on here and its on the ToDo list....pipes in the barn...
Our 1st trip is this weekend ans 85% chance of rain on Saturday so we will see...
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
04-23-2015, 07:34 AM
Ours did the same day of drying in the sun seems fine now
04-23-2015, 07:56 AM
Old Ram Guy
This may not help much with your current leak problem, but I have had two hybrids and two popups over the years and I always Scotchgard the bunk end fabric and the seams once they have had a chance to cure. I spray it on pretty heavy the first time and reapply the Scotchgard each year. I've never had a leak on any of them . . . knock on wood! Good luck and happy camping.
Marty, Jenice and DD
2019 Entegra Odyssey 29V
04-23-2015, 12:18 PM
You should have gotten some information with your camper about bunk end maintenance. I did with my 2014 233s. In this paper it stated the thread used in the bunk ends will expand in time. During fabrication, the needle leaves a hole larger than the thread. Believe it or not, adding water to the stitching, like hosing it down, will expedite the thread expansion. I removed my mattresses and hosed the heck out of it after I got the camper home. I could see water coming through the stitching. After it dried, it never leaked again. Until then you can expect to get a small amount of water through the stitching. This may not be where you're leak is stemming from, but something you can look into.
I second the PVC mod. I leave mine on when the camper is not in use, and tie them on with small bungees when in transport.
2014 Rockwood Roo 233s
2014 Runaway Navigator
2013 GMC Yukon XL
04-24-2015, 07:35 AM
Our 2014 233s had the same situation. After two or three cycles of soaking rain ( garden hose) and completely drying they have become totally weather proof. They call it seasoning the stitching. After that we experienced total down pours in thunder storms last season with no leaking.
04-24-2015, 09:35 AM
Yes.
Op - See the second picture in this thread ...
http://www.forestriverforums.com/for...nce-47753.html
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
04-24-2015, 03:04 PM
Originally Posted by Triguy
Thanks Triguy, I looked for this thread before posting but couldn't find it.
2013 GMC Yukon XL
04-27-2015, 01:30 PM
I also have a brand new hybrid and we got a good deal of rain Saturday. Yesterday I opened the bunk ends for the first time and noticed a small amount of water trickling down from the top of the seal over the window ends. Didn't see any water on the bed area at all. Is this normal? That is telling me that the mechanical seals themselves are leaking.
I thought I read somewhere that the new hybrids (or at least Roos which is what I have) don't have the rain gutter anymore, so there is nowhere to hang the PVC tubes. Am I correct?
04-27-2015, 02:47 PM
Not sure about the very latest Roo builds. I was able to bridge the pvc over the seal area, the screws that attach the bunk door frame to the wall help to capture the pvc and keep it in place. You have to slide it to the side in order to remove. Many Roo owners are using a split hose to do the same thing. Its not really a separate gutter but is part of the bunk door frame. If your bunk ends looke the same as in photo it should work for you.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
04-27-2015, 03:04 PM
I'll check it out when I get home. Thanks!
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
05-01-2015, 05:30 AM
I will blame it on it needing time to season....several more showers and its stayed dry.
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
05-01-2015, 06:05 AM
Glad to hear you've had no more leaks!
05-03-2015, 02:07 PM
Check all your zippers when we got ours both ends had zippers at top and about an inch from each other when I washed them the first time I had a small bit of water in my bunks
2014 Ford F-150 FX4 Crew 4X4 EB 3.5 Twin Turbo
2015 Roo 23IKSS Saphire
2015 (3) Nights Camped
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
06-27-2015, 02:09 AM
Silly question? you spray the inside right?
2013 F150 xtr
2012 rockwood Roo 21ss
3 Daughters And My beutifull wife
Crescent fishing kayak
Trek 3900 mountain bike
24 nights booked
06-27-2015, 05:11 AM
Spray the outside.
We didn't pre-season and let mother nature do it for us during our first outing and did get some water. Just got back from second trip where we had torrential rainstorm the first night. Not a drop got inside.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
06-27-2015, 09:44 AM
To help protect the bunk ends on our Hybrid that we no longer have I purchased solar blankets that were big enough to cover the top of the bunks and attached with clips from lowes that tighten on the bead to hold it on. This protects the end and also helps keep it cool.
You can also buy a product made for the bunk ends but they are a bit expensive.
