Old 09-10-2008, 02:50 PM   #1
Bunk end latch replacements
Anyone here updated the screw type bunk latches on their hybrids with the bar lock handle style? Mine are starting to spin loose of the knob and screw and I would like to see what hardware is out there.
turbopuppy is offline   Reply With Quote
Old 09-28-2008, 08:13 PM   #2
CampeRooo
rthrbelsewhere's Avatar
I am interested in hearing about this also...so free bump!!!
We have a 2k 18-M Roo and so far, we're lovin it!!!
Thanks!
rthrbelsewhere is offline   Reply With Quote
Old 09-29-2008, 01:40 PM   #3
This is what I'm looking for:
The original screw clamps are rusty slipping nonsense. I did find a manufacturer that has them. Part#65004 is for the handle, and #65006 for the lock at Fastec Industrial. 1-800-837-2505.
Old 09-29-2008, 02:14 PM   #4
CampeRooo
Very nice. Looks like starcraft has a set as well: Starcraft part numbers: 37012213 and 37012216. I think that I might take mine in once i find them and have the dealer install them so that if there's any problems later on, I can go back to them for it. I know that a lot of this external work is fairly simple stuff, but I just have issues cutting or drilling into anything unless i know what's in the middle or on the otherside.
Thanks for the info!
Old 10-03-2008, 03:41 AM   #5
bikendan's Avatar
i believe you can contact FR's part dept. and order them. i know other Roo/Shamrock owners have.
Old 10-26-2008, 08:40 PM   #6
wildwood's Avatar
i have a fleetwood prowler lynx ultralite, fiberglss, 2001, model 723C. i got it used, and it has been ok.
it has the screw down style bolted to fiberglass. well, the threads are now pulling out of the fiberglass and i am looking to make an imrprovement somehow.
i am interested in any ideas
thanks
phil
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 01-24-2009, 06:17 AM   #7
need a price qoute
Replacing bunk lock need price for four.
djblock75 is offline   Reply With Quote
Old 07-06-2009, 08:35 PM   #8
I made this change when I replaced my water damaged bed core from FR. I ordered the new latches as well. I needed to add a backing plate inside the camper to secure the latch arms. I used 1/4" aluminum, and stainless machine screws with lock nuts. I also used a 1/4" thick vinyl trim spacer under the latch arm for 2 reasons:
1. to cover the existing screw holes from the twist style locks, which were lower than where these arms needed to mount
2. I was concerned the amount of pressure to secure the latch would not compress the rubber pad on the latch arm. Since I was upgrading an older camper, I was not sure if it would work without the spacer. I now think it would be fine, but I still need to cover the original screw holes.
They work fantastic!
I can provide some photos if anyone is still interested.
Bob
Bob & Laura Langlois
2004 FR Shamrock 25BH
2002 Suburban
Bob Langlois is offline   Reply With Quote
Old 07-26-2009, 03:35 PM   #9
How did your bed core project go? I just bought a 21' Shamrock with damage, and I need to get the bed fixed. The damage is at the bottom of the panel, but the screws and mollies are pulling out of the panel as well.
Matt Shaver
mshaver is offline   Reply With Quote
Old 07-27-2009, 12:03 PM   #10
ladywendolyn's Avatar
We also have a 21 ft shamrock. Our scew type locks are not broken, but we would like to instal a lock or pin on them for long trips. Anyone done this?
Lady Wendolyn
2003 21 ft Forrest River Shamrock
Manitoba Canada
ladywendolyn is offline   Reply With Quote
