Old 07-07-2015, 06:07 PM   #51
Thanks so much, I will pay closer attention. so
Originally Posted by tking01_2000 View Post
Make sure you are closed up properly even a bungee cord will cause a leak if stuck in the door
Fmande is offline   Reply With Quote
Old 07-07-2015, 06:18 PM   #52
Switches Inside Door
I have no idea what the two switches are just inside ttrailer door. Any insight Rockwood Roo 23B
Old 07-07-2015, 06:42 PM   #53
Moderators' Assistant
bikendan's Avatar
You should start a separate thread for this, since has nothing to do with this thread's title.
Also pics are more helpful, especially since there only a couple of 23B owners here.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 11-10-2015, 07:44 AM   #54
Pixleys,
How much pipe did you cut out of the 2 inch pvc?
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 11-10-2015, 12:55 PM   #55
bunk end water fix pipe cut
You should cut 90 degrees, or 1/4 of the pipe.
6wate is offline   Reply With Quote
Old 11-10-2015, 01:19 PM   #56
Canadian Member
itat's Avatar
Originally Posted by fyrdad View Post
Pixleys,
Have a look at Pixley's pics here
Camper Fix by JIm Pixley | Photobucket
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 05-16-2016, 01:32 AM   #57
LOIL99's Avatar
First, Thanks Pyxleys for sharing this. Great stuff.
My questions is, is there any reason a person couldn't just use a large piece of viynl and cover the entire door during travel and storage?
I envision duct taping the top of the vinyl to the rain gutter, just like Pixleys did, but instead of only a 4" piece of vinyl, use a piece big enough that it would cover the entire door all the way down below the bottom hinges and wide enough to cover the vertical seams (like a good quality inner shower curtain). Then use velcro to secure the vinyl to the trailer outside of the vertical seams and maybe on the bottom too (if necessary).
Anyone have any thoughts on this idea? I can't imagine water could get past that setup. Or does the PVC pipe (that would be left out in this setup) do something that I am missing?
For reference, see Pixleys photo below:
2008 Rockwood Roo 23SS
2013 Toyota Tundra Platinum 5.7 L V8 4x4
Husky Quest Brake Controller
Husky Sway Control Bar (RH)
Progressive Industries EMS-HW30C
LOIL99 is offline   Reply With Quote
Old 05-16-2016, 01:46 AM   #58
vinyl over door
I think you would need very thick vinyl for this, or it would easily tear in the wind. Otherwise, it should work.
Old 09-06-2016, 10:57 PM   #59
We are having the same issue in our 2014 Roo. Find water every time in the channel inside the camper on the larger bed end. There is also an area of discoloration on the roof of the bed on the exterior in one area that seems to indicate water pooling on it for a long time. Very discouraged.
Mary Douglas is offline   Reply With Quote
Old 11-08-2016, 09:02 AM   #60
Hybrid RV Seal Cover DIY
Hi, my Hybrid is a North River, but this is what I did to my bunk ends to help protect them. This was a DIY project that I decided to do to give the seals a second layer of protection. Just a short video, let me know what you think.
https://youtu.be/FV6Kw73FI8c
jaanhalt is offline   Reply With Quote
