Old 04-09-2019, 03:56 PM   #1
Do hybrid expandable trailers let you climb on the roof?
Do they have roof ladders?
Someday will buy one, but was told no ladder on side means you cant go on the roof?
How do you work on or inspect the roof if you cant go up on the roof? Like you want to buy one used. I would want to inspect the roof before buying a used trailer.
How abut the Forrest River models can you walk on their roofs?
I like the models with 3 queen tip out beds, and a side slide.
sdowney717 is offline   Reply With Quote
Old 04-09-2019, 04:29 PM   #2
Just as confused as you
Scrapper's Avatar
Just because there isn't a factory installed ladder you definitely can get on the roofs. You need to supply your own. When the units are built the workers are on the roof to install roof membrane, ac and vents. Members who have done the factory tour have reported 3 or 4 workers on the roof at the same time. Though some people use pieces of plywood to distribute their weight more evenly.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 04-09-2019, 04:39 PM   #3
I don’t think I’ve ever seen a ladder mounted on the side of a tt.
As for a ladder indicating if a roof is walkable, that’s just wrong. I have a ladder, but the ladder was an option. It’s the same roof as the same trailer without a ladder.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 04-09-2019, 04:44 PM   #4
njfishing's Avatar
Yes the roofs on the Rockwood Roos will hold your weight (I'm 225#) and are fine to walk around on... I wouldn't have a picnic up there but I do go up a few times a year to inspect and clean the roof...
Gerry Z
2014 Roo 21DK
Honda Ridgeline
Equalizer WDH
njfishing is offline   Reply With Quote
Old 04-09-2019, 04:47 PM   #5
rsdata's Avatar
i have a 3 bunk hybrid... no place to install a ladder on front or back...
250# and I just use my 8 foot tall step ladder to get up there when I want...
take a ladder with you if buying new or used...
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 04-09-2019, 04:47 PM   #6
I do have a real tall stepladder 12 foot tall. I sppose I could take it with me to get on a roof. Will an RV dealer let me get on the roof? I can imagine them saying its not safe we dont let customers go up on the roofs. Or we inspected the roof and it is in great shape. I am kind of thinking nothing older than 5 years. My budget allows for mid 20 thousands to buy something in the mid 20 foot range.
Old 04-09-2019, 05:00 PM   #7
rsdata's Avatar
if he did not allow me to inspect the roof then I would find another dealer
look for loose or missing sealant in the seams of the roof, sides and front and back...
inside look for ceiling stains and soft spots on the floor where a leak may have been and caused the floor to rot
but most important on a hybrid is to look at the bunk end doors and the hinge area where they attach and look for soft spots, rot, water stains, and bunk door delamination ( where the fiberglass bubbles away from the side causing a big bulge) usually showing where water got into the bunk door
2014 Shamrock 183
Old 04-09-2019, 05:07 PM   #8
Good advice. How about condensation. Youtuber with one said the matresses were getting wet. like lots of water on the matress bottom blaming the humidity in the air? Anyone experience that? Their solution was to put matresses in plastic matress bags.
Old 04-09-2019, 05:18 PM   #9
rsdata's Avatar
there is often condensation in the bunk ends, especially when cool and damp outside...
think about it... high humidity in the air, in your breath, and evaporation from your body all add moisture to the bunk end... thin vinyl canvas end gets cool and condenses that moisture inside the bunk...
solution is to crack a ceiling vent, even in cold weather and unzip a bit of the tent end to provide some ventilation... I usually run a small fan, the bunk end fan all night... some go further and lay in some thin insulation under the mattress to keep out the cold...
it is the same issues in the same kinds of weather in a tent... ventilation is the key
most hybrids come with a 120 VAC electric heated mattress to help the bottom of the bunk condensation issue
2014 Shamrock 183
Old 04-09-2019, 05:55 PM   #10
bikendan's Avatar
I used my 7' ladder to get on top of my hybrid. I also put down some plywood to distribute the weight.
Never seen a Hybrid with a factory ladder because there's no place to put backers for the ladder.
Also, there are caps between the roof and the bunk doors. They will not support weight.
Equalizer WDH
roo, hybrid, roof, trailer, expandable
